Headers for my Highboy
Old Jan 19, 2004 | 10:36 AM
leadmic's Avatar
leadmic
Does anone have pictures of headers on a highboy that has the third crossmember? Im thinking of ordering a set but the out fit Im ording from (Stans headers) said that they dump under the third crossmember and Im thinking that they will hang down too low and cause ground clearance problems. So if you have any Pics please let me know.
Thanks alot Leadmic
Old Jan 20, 2004 | 01:55 PM
leadmic's Avatar
leadmic
Any one?
Old Jan 20, 2004 | 04:26 PM
4WD67F250's Avatar
4WD67F250
sorry I dont have a picture, BUT I do have headers on mine and they dump right below the third crossmember. just to each side of the lowest part of that xmember. they look ok, the driveline is hanging down even lower, so I would think the headers would be safe... my exaust runs back just under the framerails and out on each side in front of the rear tires. I didnt worry about it down there because the T-case hangs down way lower anyway.
Old Jan 20, 2004 | 05:19 PM
proeliator's Avatar
proeliator
Ditto. I assume he meant he has the (Stans) headers, as do I. Good choice.
Old Jan 20, 2004 | 06:14 PM
73highboy4x4's Avatar
73highboy4x4
i have some cheap headers made by holly, they come out under the third member, it comes close to the drive shaft with the dana 60 with a reverse rotation pinion. with the stock axle there was no problem, the passanger side is split for the motor mount, i welded mine to seal it up, i dont know if the stan's are split but they may leak if they are
Old Jan 20, 2004 | 08:56 PM
leadmic's Avatar
leadmic
Thanks for the imput still looking for pics.
leadmic
Old Jan 21, 2004 | 09:25 AM
78broncoman's Avatar
78broncoman
Hey will thoes stans headers fit a 74 highboy? Where would i beable to get them and how much do they cost? Thank you
Old Jan 21, 2004 | 01:19 PM
proeliator's Avatar
proeliator
Yup.
http://www.stansheaders.com/
Worth it to be cermacoated.
Old Jan 21, 2004 | 04:59 PM
77460ford's Avatar
77460ford
Good to trial fit the headers before the ceramic coating (nothing hurts more than banging them after). I had my Stan's coated and they came out great.
John.
Old Jan 21, 2004 | 11:10 PM
78broncoman
Is that the only ones that would fit my truck? And what would they do for me performance wise? And are they worth the 450 bucks?
leadmic
Apr 30, 2003 07:42 AM
leadmic
Jul 30, 2002 09:49 AM
leadmic
Jul 9, 2002 01:34 AM
leadmic
May 21, 2002 06:02 PM
leadmic
Car/truck Buying Advice
Feb 25, 2002 06:33 PM
