1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
315 tires
Old 07-10-2002, 02:35 PM
jalawso's Avatar
jalawso
jalawso is offline
315 tires
I talked to a guy the other day who had 315 75 16 tires on his stock premium rims. I was wondering if anyone else had done this and if they had any problems? He said he had to spot weld a washer so the tires would not rub the leaf spring. Do you guys think I could put 305's on my stock rims w/o any rubbing.
Old 07-10-2002, 02:59 PM
darth's Avatar
darth
darth is offline
315 tires
just talked with the local tire shop here, NW OR, Les Schwab. They would go as big as the 295 on the stock rims. Even then they said I might have vibrations and I should be aware of that. They also said they might not wear perfectly. I picked the 305s and they didn't want to put those on the stock rims though. I am sure it could be done, and I am sure somebody here has done it, but I chose not to.
Old 07-10-2002, 03:28 PM
CBSuperduty's Avatar
CBSuperduty
CBSuperduty is offline
315 tires
For tires that big they recommend that you use an 8" wide rim. Ford factory rims are 7". Some people do go ahead and do this but to me it is not worth my 35K dollar truck if they don't hold like they would on an 8" rim. I would only consider going to a 285 or maybe a 295. That is just my opinion though.
Old 07-10-2002, 07:19 PM
Distinctive Dave's Avatar
Distinctive Dave
Distinctive Dave is offline
315 tires
I put a set of BFG All Terrians 295/75R16 on the stock rims. About 2,500 miles on them and no problems. I know another guy that did the same thing. Seems fine. Only thing to watch is the speedo.
2001 F-350 CC Lariat 4X4 LB PSD SRW, Heated leather, off road package, western snow plow, strobe lights in parking lights and backup lights, tinted windows, pioneer cd player, rockford fosgate 1000x1 amp rocking 3 JL Audio 10W0's behind back seat, husky liners front and back, Hypermax "hot rod" chip, Hypermax pryo/boost gauge and Hypermax 3.5 inch downpipe and 5 inch exhaust.
Old 07-10-2002, 10:52 PM
superv10's Avatar
superv10
superv10 is offline
315 tires
315's require a 16x10 rim - 10 inches wide. Anything smaller causes irregular wear on the tire and reduces it's life.
You can put them on 16x8's, but they will "cup" pretty bad, plus they just don't look right.
I just put new ones on my F350 with a 2.5 " front leveling kit - with 16x8's the tires did not rub at all. With the current 16x10's, the tires look much much better , but I did have to do some slight cutting on the inside of the fender - it's all plastic and I just had to take off about 7 inches of it plus a little "slice" off the front corner of that plastic air-dam.
I too went thru Les Schwab here in the NW (ID) and they won't even mount them on the stock Ford wheel's - they are way to narrow.
Old 07-11-2002, 03:25 PM
CBSuperduty
315 tires
Superv10....Do you have the Ford 4" blocks in back?? I have seen a few trucks around here that sit like yours and decided that is how I want mine to sit. What kind of leveling kit do you have?? Your truck gets
Old 07-14-2002, 10:19 PM
micrenloy's Avatar
micrenloy
micrenloy is offline
315 tires
>life.
>way to narrow.
I can testify to this. I have 315's on my stock rims & just pulled them off to rotate and the front tires are worn so unevenly that is was causing the truck to shake bad at low speeds. I only have about 15,000 miles on them & some places have 90% tread and others have about 50%
Old 07-17-2002, 10:46 PM
superv10's Avatar
superv10
superv10 is offline
315 tires
Why thank you CB!!
Yes, I have the 4" blocks in back - I put the 2.5" leveling kit up front which made it set pretty even. It has since dropped about 1/4 inch to where it is as you see it in the pictures... I like it right where it is as it fits in the garage with about 1/2 inch to spare...:-
btw, my leveling kit was from Tuff Country.
Old 07-17-2002, 11:46 PM
Outpost22's Avatar
Outpost22
Outpost22 is offline
315 tires
cherrybomb37
01-17-2014 08:30 AM
maxod175
09-22-2011 07:36 AM
mobriensnow
01-11-2009 04:33 PM
BLUELINERACING
22
08-26-2007 11:44 AM
dlevey
06-10-2004 08:49 AM
Quick Reply: 315 tires
