Replacing Ammeter with Voltmeter
Old Jan 19, 2004 | 12:05 AM
Torque1st's Avatar
Torque1st
Posting Legend
Does anyone know of an application that has a voltmeter with the same form factor as the ammeter in our trucks? I would like to use a voltmeter rather than trying to use an ammeter on my reworked electrical system.
Old Jan 19, 2004 | 09:01 AM
beartracks's Avatar
beartracks
I remember a post a while back where a guy used a voltmeter out of a "Nissan" or datsun I believe.
Old Jan 19, 2004 | 04:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks, I found it:
https://www.ford-trucks.com/forums/s...er%252Bammeter
The meter out of a 70's 280Z fits, there may be others if I just look in enuf vehicles in the scrap yards.
Your memory is good, that post was 2 years old.
I was kind of hoping to find a unit out of a Ford HD truck that would work
Old Jan 21, 2004 | 09:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
Anybody else know of a replacement that will work?
Old Jan 21, 2004 | 02:04 PM
beartracks's Avatar
beartracks
What memory? Actually I would like to do this myself. I hate to modify the stock cluster but the ammeters never work well. I also have half the Auto Meter catalog hanging off the dash and steering column and would like to get rid of one or two of them.
Old Jan 21, 2004 | 03:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have 4 clusters to play with so I can afford to mess one or two up getting it right.
The ammeter works OK in the stock configuration if you go thru and solder and clean all the connections. There is a very small current signal that makes it work and one bad connection will ruin the reading.
If you start adding circuits off the battery like a big amp or bright headlight relays etc the ammeter no longer measures all of the current flowing so it does not work right. I have always liked voltmeters better anyway.
Old Jan 22, 2004 | 01:03 PM
Torque1st's Avatar
Torque1st
Posting Legend
Any other combinations fit??? I would like to have options to search for when I go junkyarding.
Old Jan 22, 2004 | 04:55 PM
grapegravy's Avatar
grapegravy
I recall noticing them in some of the Heavy Trucks and school buses. One of my old boss' 74 (?) Ford Dump Truck had one. Can't recall what size it was exactly. That'd be the first place I'd look, anyway. Good luck, let us know where you track them down.
Old Jan 22, 2004 | 05:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
Was that dump truck an individual gage or was it part of a cluster. The worst part of this is that the ammeter gage sits upside down. There are a number of gages available that sit right side up. My Ford Explorer has a voltmeter that sits upside down but it is a newer style gage without any scale To me a voltmeter must have a scale of some sort.
tbruz
Jul 8, 2015 12:46 PM
49willard
Jun 24, 2015 04:22 AM
6978sghfbjklgdfsjhkl
Sep 1, 2013 07:08 AM
Millenium Edition
Apr 11, 2012 01:47 PM
johnson2007
18
Jun 13, 2011 11:09 PM
