Sponsored by: Real Truck
atf
Old Jan 18, 2004 | 09:48 PM
tom2tom's Avatar
tom2tom
atf
aFTER the ATF change,
Old Jan 18, 2004 | 10:28 PM
DS02F250's Avatar
DS02F250
uh, yeah..... "after the atf change" what???
Old Jan 19, 2004 | 09:11 AM
99f350sd's Avatar
99f350sd
Is that a new song!
Old Jan 19, 2004 | 09:56 AM
Streetcruzer's Avatar
Streetcruzer
Originally posted by 99f350sd
Is that a new song!
Old Jan 19, 2004 | 10:25 AM
DS02F250's Avatar
DS02F250
Well, I sent tom2tom an E-mail asking for more info. Guess he'll reply when he checks his E's again... Until then, oh well...
Old Jan 19, 2004 | 10:54 AM
FortyFords's Avatar
FortyFords
Musta been a computer crash or ,he was so upset at the football games ,or had to to go the bathroom!!!!!!!
TomTom comeback !!!!!!
you alright !!!!!!!
Rich
Old Jan 19, 2004 | 11:04 AM
tom2tom's Avatar
tom2tom
Thumbs up hey
I 'm here ! i had to run to wall world for a tranny funnel, this will be my first Tran. oil change, so i am a little hesitate.Has to be the exact ATF oil(mercon) not mercon V, THEM THE CONTAINER SAID dextron III- mercon, so i was trying to get ready for the job at hand and review some of the ATF post's. Thanks everyone for the help, Need to get the filter, and about 17/18 quarts of MERCON! and some beer for after. will stop by the NAPA FOR FILTER AND OIL.
Old Jan 19, 2004 | 07:16 PM
DS02F250's Avatar
DS02F250
tom2tom,
Good luck on the fluid & filter change. Remember, it is RECOMMENDED that you re-use the OE tranny gasket (so long as it's still in good condition). If the gasket is shot, get a new one from Ford; don't get an aftermarket gasket. If Ford did one thing correctly on the tranny, it's the gasket. Don't over-torque either; just "snug". Give the old filter a "wriggle" back and forth to remove; seat the new one the same way. After you complete the filter & fluid change, start it up, look for leaks (if ok, then) give it a test drive (a few miles s/b fine so long as it goes up and down the gear range). Double-check the tranny fluid level again for accuracy.
And... you're done! Kick back, have a cold one, and revel in a job well done!!!
Old Jan 19, 2004 | 08:04 PM
tom2tom's Avatar
tom2tom
Thumbs up
DS59F100, Thanks for the help will be tackling the job w/in 2weeks, my 250 has 32000 on it although FORD installed anew tranny right around 1500-2000 miles ,i would have to look up the paper work, the pan ...wellit would'ent leak the oilk would form around the lip of the pan in certain areas, i took it back , 1st time i think they replaced the front seal , cannot account for the next time any way they put a Brand new Tranny in from the factory, w/ the green tag and all, not rebuilt , made sure. Thanks again will keep you updated.
