Sponsored by: Real Truck
4x4 Shift on the fly question
Old Jan 5, 2004 | 09:02 PM
BaadFowd's Avatar
BaadFowd
I will be ordering my new truck soon: F250 V10 4X4 CC LB MS 430LS and was wondering if I really need the [shift on fly] option - I'm trying to keep the price down - so - if pushing a button instead of shifting a lever is the only difference - I can do without it - I'm also canceling a bunch of other options that I really don't need - knocking off another $2000 for that ! - Thanks for your help.
Old Jan 5, 2004 | 09:06 PM
Ev2Demon's Avatar
Ev2Demon
The manual transfer case is shift on the fly as long as you have the hubs locked in. Personally, I know too many peoplewho have had too many problems with the electronic transfer cases for me to recommend spending the money on it. If you can't be a man and get out and lock the hubs, buy a H2.
Old Jan 5, 2004 | 09:08 PM
GreatWhite02's Avatar
GreatWhite02
Order the manual the shifter and manual locking hub, in my opinion this is a better setup with no vaccuum leaks or stubborn soleniods to hassle with.
Old Jan 5, 2004 | 10:28 PM
Badford's Avatar
Badford
the manual is better as far as less probs, but unless you leave your hubs locked in it 's a pain . i have had the shift on the fly in my explorer's and trucks since 1994 and never had a prob knock on wood.
Tony
Old Jan 5, 2004 | 10:52 PM
Bowcop's Avatar
Bowcop
I would never buy a rig that did not have the manual transfer case. It's the only way to go. I never have to wonder if it's working, cause I know it is!
Old Jan 6, 2004 | 10:08 AM
LK's Avatar
LK
As others have said, go with the manual t-case and manual hubs - it's far more reliable. I bought my '04 F250 off the lot, and it came with the electronic system...and it doesn't work very well at all. While it *usually* goes into 4wd (sometimes with a loud thunk that shakes the truck), sometimes it seems to refuse to go back into 2wd again - and to get it out of 4wd I have to stop and back up while turning back and forth (sometimes I have to repeat this several times). The manual says that you don't have to back up, but that it 'helps' it come out of 4wd...but in my truck's case, if you don't back up it won't come out, and even when you do back up it sometimes still doesn't come out.
This is the first truck I've had with ESOF - and so far I'm not impressed. With my trucks with manual hubs, I just left them locked in all winter...which worked better, and was a heck of a lot more reliable.
LK
Old Jan 6, 2004 | 10:47 AM
Big Orn's Avatar
Big Orn
This is a matter of opinion. The ESOF is designed to work as effeciently as the manual shift, but, as with all components that rely on electronics, it can have unique problems.
My opinion: I like the ESOF - alot. I have a theory, but so far, have not had the feedback I would have expected from others who have the ESOF. I believe that the PCM needs to "learn" how to initialize/energize the system. At first I was disappointed with the setup, but after going through a little hands-on training, realized that the ESOF needed to be energized occasionally in order to work properly. Now, every time I turn the switch, the system reacts, promptly. No hassle.
Old Jan 6, 2004 | 12:28 PM
bstrom's Avatar
bstrom
The Fords have a hub set-up that is in auto mode always and then you can still get out of the truck and manually lock in the hubs. I have had several auto lock Fords and they always have worked well. Seems to me with the new style hub, I have the best of both worlds.
Bill.
Old Jan 6, 2004 | 01:16 PM
LK's Avatar
LK
I was wondering about this - if it would get better with time. So far I've got about 5,000 miles on my '04, and have probably had it into 4wd perhaps 50 times - I usually have it in once a day or so, when I'm out in the pasture dropping off hay or hauling manure (especially with snow on the ground). I think it's gotten a bit better about going into 4wd, but it still doesn't want to go back into 2wd again.
The thing that bugs me is that the '4wd' light goes out right away when I put it in 2wd, but in reality it's still in 4wd - I think it's shifted out, and then I go out on the road and when I try to make a sharp turn it binds up because it's still in 4wd (sometimes several miles from where I put it in 2wd). At the very least it'd be nice if the light stayed on until I was *really* out of 4wd...then I'd know how far I had to back up to get it to come out. As it is, I usually back up until I feel it should have come out, and then nail the gas to see if only the rears spin or all four spin - if only the rears spin, then I know I'm really in 2wd.
LK
Old Jan 6, 2004 | 01:17 PM
RB1's Avatar
RB1
[QUOTE]Originally posted by EV2DEMON
[B]The manual transfer case is shift on the fly as long as you have the hubs locked in.
I don't think that is true... shift on the fly means (up to an allowed speed) you can shift while driving, into 4WD. I don't think you can do that with manuals, even with the hubs locked in, at say, 45mph...
Old Jan 6, 2004 | 01:28 PM
DMC's Avatar
DMC
The owners manual states that the manual shifter can be engaged at up to speeds of 55mph from 2WD to 4WD High if the hubs are locked.
Old Jan 6, 2004 | 01:36 PM
Big Orn's Avatar
Big Orn
LK
This could be the hubs, LK. When the light goes out the transfer case is disengaged, but maybe the hubs are still locked, giving you the impression (or feel) that it is still in 4WD.
I haven't had this problem. My problem was switching the transfer case - the light would remain "on" or "off", nothing would happen. I have seen a few posts here where people have had that problem (hubs remained locked after disengaging). You might try a search?
Old Jan 6, 2004 | 02:09 PM
ford 2 fitty's Avatar
ford 2 fitty
ok I am confused... I have the manul 4wd and the manual hubs.. I can leave the hubs in the locked position and just put it into and out of 4wd without adjust the hubs.
It doesnt do anything to the hubs to have them in the locked position all winter?
Old Jan 6, 2004 | 03:01 PM
garymake's Avatar
garymake
doen't hurt a thing to leave the hubs locked all winter - mine have been locked since October. When I need 4wd, I just reach down and pull the lever.
Works like a charm!
Old Jan 6, 2004 | 03:08 PM
LK's Avatar
LK
The binding is pretty severe - when you turn a sharp corner on bare pavement, you can feel the truck jerking and actually sliding the tires. I'm pretty sure it's the t-case that isn't shifting out, because when it's in 2wd and I lock both the front hubs and turn it doesn't bind much at all. Basically, the truck acts just like my older manual-hub trucks do when when the t-case is locked in 4wd...which seems to indicate that the t-case is still engaged *and* the hubs are still locked in.
Also, when I have the hubs in the 'lock' position it still occasionally refuses to come out of 4wd - which I think points to the t-case, or perhaps to the switch in the dash.
I'm not sure exactly what's going on - I'm really far more familiar with the old manual-hub systems, and haven't really looked into the mechanicals of the ESOF system.
LK
