Modular V10 (6.8l)
Whipple?
Old Feb 25, 2005 | 05:23 PM
kenneBF250V10's Avatar
kenneBF250V10
I have a Kenne Bell running 7 lbs of boost and I love it. Easy install and lots of extra power.
Old Feb 25, 2005 | 05:44 PM
etcetera's Avatar
etcetera
When the time comes I've been thinking of the paxton kit. I wonder about using a stock diesel intercooler and some custom piping with the cheaper paxton kit.
Eric
Old Feb 25, 2005 | 10:34 PM
V10MARS's Avatar
V10MARS
Question
Originally Posted by agritron
I have a whipple supercharger on my 2000 V-10. I am very pleased with it and would be happy to answer any questions you have about it.
OK.
How much $$ above the SC kit did you have to spend. (Injectors/chip etc)
Do you do any towing with it and how is the day to day driving.
How long have you had it.
TIA.
Old Feb 28, 2005 | 09:09 AM
V10MARS's Avatar
V10MARS
Hi agritron, ya still here?
Old Feb 28, 2005 | 10:54 AM
68 351 bronc's Avatar
68 351 bronc
Go to the Whipple web site and you will find the kit for the v-10. Around $4000 dollars.
Here is a forum that is all about blown Ford Mod motors. www.got-pressure.com
Old Mar 2, 2005 | 11:41 PM
V-10Triton's Avatar
V-10Triton
Injectors? did you guys go with larger injectors? if so was there any additional truoble with the dyno tuning?
Old Mar 3, 2005 | 06:07 PM
68 351 bronc
The Whipple Kit includes a couple of injectors that are installed in the intake and richen the fuel /air ratio as needed.
With the whipple kit it is designed to work with stock exhaust manifolds as well as stock injectors. A year ago they did not offer an intercooler for the V-10 or SD. But now that Ford builds and intercooler for the 6.0 diesel I am sure that one could be adapted.
Old Mar 3, 2005 | 10:12 PM
etcetera's Avatar
etcetera
The 7.3's had intercoolers also. I think it's usually water to air for blower type superchargers. A small radiator is basically sandwiched between the blower and the intake, cool water is circulated between that and a bigger radiator out in front of the regular radiator, ac condensor, tranny cooler, etc.
The Air-Air intercooler works well with turbos, and Paxton style superchargers.
Eric
Old Mar 3, 2005 | 10:32 PM
68 351 bronc
I was saying that Whipple did not offer a inter cooler for the V-10.
No air to air, or water to air. But that a factory 6.0 air to air could be adapted.
The Whipple is a Twin Screw, positive displacement, at any rpm, type blower.
The Paxton is a centrifugal type, meaning its a fan that blows air IF it is spinning fast enough.
Old Mar 3, 2005 | 10:39 PM
etcetera's Avatar
etcetera
I agree, but I'm saying the whipple is actually bolted directly to the intake manifold. Kind of hard to get the hot compressed air through the intercooler before it gets to the manifold. Unless you mean using the ford intercooler as a water-water. Should work, all that would have to be fabricated is the piece that goes between the blower and manifold, and whatever hoses. The piece that goes between the blower and manifold will be a bit tricky. The body of it has to be strong enough to support the blower, and have basically a radiator inside. The drive belt would need to be longer. I haven't measured one, but there might be a clearance problem with the hood.
Eric
Old Mar 4, 2005 | 11:30 PM
68 351 bronc
The factory 6.0 air to air I am refering to is mounted to the core support like a radiator. Whipple did not design their kit to NEED and intercooler but could only benifit from one.
Old Mar 5, 2005 | 12:37 AM
etcetera's Avatar
etcetera
I agree again. But it's still next to imposible to use an air to air with a whipple type supercharger. Water to air is the way to go in this application. The 6.0 and 7.3 intercoolers are virtually identical, one might be a bit different in size, but they both mount and work the same way.
Old Mar 5, 2005 | 11:18 PM
  #28
mstennes's Avatar
mstennes
Question
What type of milage did do you have? I cant decide which I want Whipple or Kenne Bell need some pros and cons here? I'm also thinking of a cam but who makes one of those for a v10? I have a K&N FIPK, Gibson Headers with duals all the way to the back with dual high flow cats, Super Chips Micro tuner and I still want more!!!!
Thanks,
Mike
Mahosky
Apr 27, 2016 06:34 AM
62bugman
Mar 29, 2016 01:01 PM
topscrt
Modular V10 (6.8l)
Oct 18, 2010 09:35 AM
Ragger
2004 - 2008 F150
Aug 19, 2009 03:49 PM
rocklayer
3.0L V6
Mar 16, 2004 07:34 PM
