No more Overdrive?
Old Jan 31, 2004 | 09:17 AM
MarksTRK's Avatar
MarksTRK
Well... There are no codes to pull from the OBD-I. I guess I will have to look into transmissions..... Thanks all-
Mark
Old Feb 1, 2004 | 08:57 PM
Ken00's Avatar
Ken00
I'll dig out my 1989 manual and see if I can give you some more stuff to look at.
Old Feb 2, 2004 | 07:58 AM
MarksTRK's Avatar
MarksTRK
TY, I am intersted to see how this sub system is inter-connected. Maybe something form your manual will shed some light.
Mark
Old Feb 3, 2004 | 07:22 PM
Ken00's Avatar
Ken00
Since your not getting any codes I will only list the possible causes that would NOT cause a code.
Bad wiring, pin 57 ( red power wire) and pin 52 (blk wire) should be 20 ohms.
Bad ECU.
Converter clutch solenoid jammed, drop pan, valve body and check solenoid.
Converter clutch shuttle valve stuck, remove valve body and check, the spring load should be 2# at 0.512".
Converter clutch valve stuck, remove valve body and check operation.
Converter malfunction, replace converter.
Old Feb 3, 2004 | 07:58 PM
MarksTRK's Avatar
MarksTRK
Thanks Ken. That should give me a few things to check and maybe offset some major expence. I really appreciate your effort.
Mark
Old Feb 3, 2004 | 08:05 PM
Ken00's Avatar
Ken00
Lets us know how things go.
wameyer
Nov 15, 2013 10:32 PM
leadpoison
Electrical Systems/Wiring
Feb 23, 2013 05:34 PM
Fuelhog 5212
13
Sep 14, 2009 07:06 PM
Bigtony4
2004 - 2008 F150
18
Jun 22, 2008 03:13 PM
Renegade25
Jun 6, 2007 11:34 AM
