Sponsored by: Real Truck
Power Door Locks
Old May 23, 2002 | 06:27 PM
Richierich's Avatar
Richierich
Power Door Locks
Has anyone had any problems with their power door locks not locking.
I have 1999 F250 Lariat with remote power locks. It tries to lock (remote)and unlock the drivers door, but rarely succeeds. On the other three, it usuall does but sometimes it misses the front passengers side or the back pasengers side. Also the same when using the auto button inside. The remote when pressed once is supposed to unlock the drivers door and when pressed twice, the rest of the doors. If I relock them and try again, then it seems to be worse. If left alone for a long time it sometimes works correctly. Is there some sort of relay somewhere that might be bad or what??
Old May 23, 2002 | 07:01 PM
Monsta's Avatar
Monsta
Sit. Stay.
Power Door Locks
I'm a bit confused. (easy to do.)
Do you experience the same exact locking/unlocking problems when using the inside switch as you do when you use the key fob?
If not, then I would ask, "When was the last time you changed the battery in the key fob?"
If so, then I may suspect the door lock actuators.
Let me (us) know.
Old May 23, 2002 | 07:24 PM
Richierich's Avatar
Richierich
Power Door Locks
Battery OK in remote. same on inside switch, but different result everytime is pressed. Surely not all accuators bad, only 27000 miles on truck. Different locks work correctly at different times. Mabey possessed with demons.
Old May 23, 2002 | 07:49 PM
Monsta's Avatar
Monsta
Sit. Stay.
Power Door Locks
>>Maybe possessed with demons.
Yes! Take it to your local exorcist, er I mean, dealer! Tell 'em to change stuff until it's fixed. They like doin' stuff like that.
Old May 23, 2002 | 08:10 PM
NoMo's Avatar
NoMo
Power Door Locks
You'll definitely want to get the truck serviced... I think the GEM controls the door locks as well as several other miscellaneous functions. Probably only a matter of time before other "gremlins" appear.
Old Jun 1, 2002 | 09:02 PM
ergopilot's Avatar
ergopilot
Power Door Locks
I've got the same problem with my 2000 F250 SD. The hotter the day, the worse it works. It doesn't matter if using the key fob or the inside switch. I'm in Phoenix, and in the summer, forget it. They are too hot to work. This probably means there's not enough power getting to the solenoid (the hotter the coil, the higher the internal resistance, and the more current it will take to actuate the lock). There must be something limiting the current somewhere. I'm taking mine in to Ford in a couple weeks and will see what's up...
I've also got a problem with my Cruise control dropping out when I hit a bump, so that will be looked at too....
I'll try to remember to let you know what I find....
Old Jun 3, 2002 | 11:55 AM
Richierich's Avatar
Richierich
Power Door Locks
[updated:LAST EDITED ON 03-Jun-02 AT 12:56 PM (EST)]Mine is the same way. Let me know what they came up with.. w5xv@arrl.net
Old Jun 3, 2002 | 01:13 PM
FortyFords's Avatar
FortyFords
Power Door Locks
Chk the connector on the fire wall it hAS A 5/16 (i think) bolt going through it some have made it through the factory loose.
This direct from a ford friend of mine.
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old Jul 24, 2002 | 09:28 PM
Big_Blue1's Avatar
Big_Blue1
Power Door Locks
I bought a 99 250 about a month ago and I am having a similar problem.....The lock actuators want to work but they seem to not have enough power. It almost looks like they are "gummed up". They are about $70 a piece to remove and I would like to avoid that if possible. Did anyone ever find a simple solution to this problem? -John
Old Jul 25, 2002 | 01:46 PM
ForDen's Avatar
ForDen
Power Door Locks
Old Jul 25, 2002 | 07:35 PM
infinity's Avatar
infinity
Power Door Locks
I have a 02 v-10 SD and am also having just a slight problem with my RKE system. Just sometimes, when I hit the un-lock. It will not un-lock the first time. The same gois for the lock. Maybe it is because of the rolling RKE system. Any help out there?
Old Jul 25, 2002 | 08:42 PM
jmpd's Avatar
jmpd
Power Door Locks
[updated:LAST EDITED ON 25-Jul-02 AT 09:44 PM (EST)]See the EX forum "Door lock actuators"
Seems to be a Ford Problem
My Ex does the same thing 47K
In Phoenix the hotter it is the less they work, Inside switch or key chain
Michael
NavyPowerstroker
Feb 4, 2012 09:10 PM
Nite Ranger
1983 - 2012 Ranger & B-Series
May 31, 2010 12:13 AM
bbeaumont
Dec 19, 2006 11:10 AM
