Weird Exuast note
Old Jan 17, 2004 | 12:41 AM
640 CI Aluminum FORD's Avatar
Weird Exuast note
My aunt just bought a 2004 Ford Exc V-10 4wd I drove it threw town the other day and the Muffler sounded like it had a leak under normal acclration it sounded kinda like a vacum cleaner
dose anybody no whats wrong??? or is this normal???
Old Sep 13, 2007 | 01:35 PM
Dereck's Avatar
Dereck
Hi 640ci Aluminum Ford
I think your Auntie must have bought the "Oreck" limited edition
Regards
Dereck
Old Sep 13, 2007 | 01:39 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
A 'rattle' like sound or more of a misguided rumble? Could be a loose heat shield or something...on my old Explorer...the way they tack weld the shields on...well they can fracture the welds and the shield vibrates. My fix was like many others...get yourself a LARGE stainless steel hose clamp and put it around the whole thing and snug it tight...may take two depending on which shield...just a thought on what may be the cause...
Good luck,
joe.
Old Sep 13, 2007 | 01:56 PM
MarkMoore's Avatar
MarkMoore
I've found 2 things on my X that cause rattling noises...
1 - was the flywheel inspection shield on the front of the tranny. Loosend it up and put in a little weatherstripping tape I had (right long the outer edge) and tighened everything back down. That hushed up that problem.
2 - My CAT heatshield is now loose and rattles; mostley at idle, but at cruising speeds as well. Maybe I just don't notice it as much at speed, but if I get next to the interstate divider, I can hear it. Anyhow - I need to stoop off at the local muffler shop and have them re-weld it. They'll do a better job than the OEM and it should last the remaining lifetime of the CAT.
MisterRanger
1983 - 2012 Ranger & B-Series
20
Aug 23, 2011 06:56 AM
yz450kid
Jan 26, 2006 11:13 PM
TheYeti
Modular V10 (6.8l)
Aug 14, 2005 01:43 PM
ford390gashog
Modular V8 (4.6L, 5.4L)
15
Nov 10, 2004 07:07 AM
Ky Ford f150
1997 - 2003 F150
Mar 24, 2004 06:48 PM
