High EGT's
Old Feb 25, 2004 | 08:22 PM
  #46
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
wlihntr:
Sounds like you've got it covered.
RRMike:
Both leads have ring terminals on both ends. You can just take them off for safe keeping. You will have to reattach the blue wire on the solenoid end of the hot wire to prevent setting a code.
Old Feb 29, 2004 | 02:25 AM
  #47
not2litl's Avatar
not2litl
today i tried my best to get my EGT's as high as eveyone else running with the predator
I put it on 60hp and i couldnt get over 1050 deg. from a dead stop to 80mph
tried several times but just couldnt get the temps
80mph @ about 2250 rpm 1050 deg.
may i was getting better air than the rest
Old Feb 29, 2004 | 07:13 PM
  #48
nhancock's Avatar
nhancock
not2litl,
Out of curiosity, what mods have you made to your truck?
Also, just to verify, was your probe pre-turbo?
Old Feb 29, 2004 | 10:59 PM
  #49
not2litl's Avatar
not2litl
probe tapped into exhaust manifold
Ford AIS intake
4" turbo back w/aeroturbine muffler
wastegate disabled
Old Feb 29, 2004 | 11:42 PM
  #50
horsecop's Avatar
horsecop
not2litl, have you pulled anything yet? EGT's sound good but put a 36' Sundowner w/living quarters, full 40 gallon water tank, 2 horses and a bunch of tack, then see what they are. That's why I put the 40 hp. chip back in!
Old Mar 1, 2004 | 06:32 AM
  #51
nhancock's Avatar
nhancock
not2litl,
Go buy a lottery ticket. It sounds like you've got better luck than the rest of us.
I'm glad your setup is working for you.
Old Mar 1, 2004 | 07:54 AM
  #52
not2litl's Avatar
not2litl
horsecop the only thing i have pulled is my 38' TT but not for extended periods of time....but I am sure the EGT's would rise under a load like that....I was trying to simulate nhancock dilemma so I could post my findings.....
Old Mar 1, 2004 | 09:37 AM
  #53
horsecop's Avatar
horsecop
I sure miss the power around town when the 80 was in there, but I don't mind. Gives me a reason to turn up the Alpine and watch the gals!
Old Mar 2, 2004 | 03:47 AM
  #54
not2litl's Avatar
not2litl
i just cant get the high egt's 25lbs of boost 85 mph 2300 rpm 1050 deg....i can get higher egt's if i ride the brake...but so far thats the only way
Old Aug 31, 2010 | 01:46 PM
  #55
Jerry Edwards's Avatar
Jerry Edwards
High Egt
Originally Posted by Dieselsmoke
You guys worry too much. I've seen the pyro go around as fast as the tachometer. It stops at 1650 and it's been there many times since 1999.
I have a 2002 F250 4x4,with 5" exaust,Gryphon Programmer,and KnN Kit.It has seen 1450 EGT,Towing in stage one,(60 Horse Power).Towing up a hill,that worries me.I would like to be able to lower it.Any ideas guys?
bolawson
Sep 23, 2008 09:18 PM
Tampa250
Jun 23, 2005 06:51 PM
johnny8
23
Jun 19, 2005 12:30 PM
BagStroke
May 6, 2004 09:13 AM
eeglot
Computer Chips & Tuners
Apr 1, 2004 05:37 PM
