distributor 351M
Old Jan 15, 2004 | 08:05 PM
bubba333's Avatar
bubba333
distributor 351M
Was replacing the distributor and the truck got pushed. I was told to remove #1 plug and slowly crank motor until compression was felt, then to crank motor until pointer and 0 degrees lined up. I could never get the pointer and 0 to line up. Am I doing the right thing? Help, PLease!!!!
Old Jan 15, 2004 | 08:23 PM
Ecuri's Avatar
Ecuri
Take all your plugs out and turn it over with a socket on the crank nut. The compression on the other cylinders is making it hard for you to land where you want. This also makes it easier to rock the engine when stabbing the distributor to get it to land on the pump drive rod. GL
Old Jan 16, 2004 | 11:12 AM
bubba333's Avatar
bubba333
I'll give that a shot. Thanks
Old Jan 17, 2004 | 12:55 AM
There Goes The Neighborhood's Avatar
Maybe I did it wrong, but the last time I took plugs out and tried to turn it over with a breaker bar, the socket slipped off and it spun over 3 times. Oh, I get it, the socket has to stay ON the balancer bolt.
Old Jan 17, 2004 | 03:44 AM
Torque1st's Avatar
Torque1st
Posting Legend
That must have been an ARMSTRONG wrench
cdat81986
Sep 3, 2011 11:15 AM
marshpoprock
Aug 15, 2011 11:09 PM
blkempinc
Feb 14, 2010 08:30 AM
Jupes
Sep 4, 2009 09:54 PM
Kustomfiend
May 9, 2009 07:06 PM
