Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Jacks and Stands...
Old Jan 14, 2004 | 08:09 PM
PDawson's Avatar
PDawson
Jacks and Stands...
Im currently out of the engine phase on my '64 f1oo. Now Im going to get started on some other things...such as wheels, cylinders, blah blah blah...and so forth.
I have a small bottle jack that isnt worth diddly squat and I was wondering if you guys had any input on what type of jack and stands I need. Im looking at a 2 3/4 ton jack, but will this be enough for the truck???
Also, are there any jack stands I need to def get or any I need to steer clear of???
BTW, I want some that will last years and years....maybe pass off to my son when he gets older.....
Thanks In Advance,
Phillip
Old Jan 14, 2004 | 10:59 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
How high do you plan on lifting your truck? You need jack stands to go at least as high as the jack will lift.
Get the heaviest stands you can afford.
Old Jan 15, 2004 | 12:03 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check out the search function. There are a couple of threads here with lots of info on lifting and supporting vehicles.
Old Jan 15, 2004 | 05:36 AM
wdsmithjr's Avatar
wdsmithjr
I like the 6 ton jack stands, not that anything I own is that heavy but because of the height you can get out of them. Also they have a wide "footprint" for stability. Same for my jack, 6 ton too.
Old Jan 15, 2004 | 06:55 AM
BLK94F150's Avatar
BLK94F150
Sears usually has a 3.5 ton jack with two 3 ton stands for a reasonable price. Pick up some more stands and you're set.
Mike
Old Jan 15, 2004 | 11:10 AM
Huntsman's Avatar
Huntsman
wdsmithjr is right about the height and footprint of the jack stands. I have both sizes and never would have bought the stds. had I bought and used the heavys first. Depending on their use, I have had to set the short ones on 2X8 blocks to get them high enough at times.
Old Jan 19, 2004 | 03:28 AM
bigrigfixer
The Pacifier
Oh, yeah. The foot print thing.
Let me add this. Don't just get 2. Make sure you get 4.
Old Jan 22, 2004 | 05:47 AM
MrOldV8's Avatar
MrOldV8
Avoid the ones with the steel tube and pin setup...go for the ones with a cast center section. I bought some heavy duty ones in the 1960's, and I still use them. They have a very wide base, are made of angle iron and castings and are tall...great for truck frames! I also keep some smaller ones around...the kind with the base formed from heavy steel plate. There are times I need em both.
MR
Old Jan 23, 2004 | 09:59 AM
beartracks's Avatar
beartracks
I would definitely go for over kill on the jack stands. Especially for the rear if you ever need to lift by the frame. I picked up 7 ton units from Harbor freight on sale cheap. They are quite tall.
Old Jan 26, 2004 | 11:05 AM
Rick Stan's Avatar
Rick Stan
These are what I have for my truck.
Stands
http://www.sears.com/sr/javasr/produ...id=00950159000
Jack
http://www.sears.com/sr/javasr/produ...id=00950143000
Old Jan 26, 2004 | 07:11 PM
beeboy's Avatar
beeboy
Anyone use the aluminum floor jacks? I am very interested in them because of the weight savings, though they do not seem to go as high in capacity. They max out around 2.5 tons.
Old Jan 26, 2004 | 08:17 PM
Andysutt's Avatar
Andysutt
Jegs has a aluminum jack I am very intersted in.
149 bucks... I priced a AC Delco and a Lincoln jack at our local parts store today and they were priced 169 and 225 respectively
I wont be buying one of those
As for jack stands, I have the smaller ones and I HATE them. I will be buying bigger ones from now on
Old Jan 26, 2004 | 10:52 PM
beeboy's Avatar
beeboy
I'm eyeing the $199 that sears has, its rated for 2 tons, a bit higher than the Jegs one.
Old Jan 27, 2004 | 02:02 PM
92exploder's Avatar
92exploder
costco has a pretty nice 3 ton(i think) service jack for $69. looks like a nice piece
Old Jan 27, 2004 | 08:45 PM
ItzKwik's Avatar
ItzKwik
Just got a 6 ton set from Advance Auto. Were on sale for $29 a pair. Go up to 24". Didn't seem too bad for the price. So far, so good.
