trans question
Old Jan 14, 2004 | 07:44 PM
rancherman84's Avatar
rancherman84
trans question
are the e4od and 4r100w the same trans?is the 4r100w any heavier duty than the e4od.will the 4r100w bolt in place of the e4od?
Old Jan 17, 2004 | 01:35 PM
rancherman84
no responses,wanted to put it back up top.
Old Jan 17, 2004 | 03:09 PM
Clubwagon's Avatar
Clubwagon
No the E4OD and 4R100 are not the same transmission. They are very similar but not identical. There are some subtle difference in the two. Among the differences are some updated internals like the bearing type center support and a six pinion rear planentary, valve body and solenoid pack and the addition of a turbine sensor on the top of the case.
The 4R100 is slightly stronger due to the revision mentioned above. A 4R100 will not replace an E4OD because of the slight differences in the electronics. Most notably, the addition of the turbine sensor on the 4R100.
Steve
jerrytown2001
16
Dec 27, 2019 05:24 PM
20powerstroke02
Feb 14, 2017 12:06 AM
kyle.good
Oct 15, 2015 09:59 AM
Rocketattack
63
Jan 5, 2011 09:45 PM
Jrock909
May 28, 2007 12:51 AM
