Solar Panels
Old Jan 14, 2004 | 03:45 PM
Matts72's Avatar
Matts72
Solar Panels
Ok well, I picked up a panel. Its a 1000W 23.4 Volt Unisolar panel.
I was curious what the value of the panel might be, and what a transformer would cost to turn the output into 110V, so its useful.
Thanks
Old Jan 14, 2004 | 03:48 PM
drunkenmonk's Avatar
drunkenmonk
you'll need an inverter, transformers run on AC, and panels output DC
Old Jan 14, 2004 | 03:50 PM
Matts72's Avatar
Matts72
Ok, I just looked on Ebay, and these things are quite valuable.
So, an Inverter, is that it?
Old Jan 14, 2004 | 04:25 PM
otto's Avatar
otto
im not sure your gonna step that up to 110 volts with much more than one usable amp, will an amp even power a transistor radio
Im not sure and sure hope its not true, how big is it ?
Old Jan 14, 2004 | 04:30 PM
Mike W's Avatar
Mike W
I believe a 50 watt, 12 volt panel is around $400. How large is it?
Old Jan 14, 2004 | 07:05 PM
dcexplorer's Avatar
dcexplorer
Re: Solar Panels
Thanks
You need a 24 volt inverter. Look on Ebay.
Actually, you probably need to have the panel charge a battery, then power the inverter off the battery. That's what I do for the lights and radio in my utility shed.
Old Jan 14, 2004 | 09:37 PM
hreed's Avatar
hreed
Watts=Volts X Amps so you have a (round numbers) 4 amp output. That won't convert much for you into 120 or run anything very long. Usually, those panels are set up in parallel, with 10-20 hooked into the system. Then you can get some use. 1 panel by itself isn't too useful. And then the sun has to be shining!
Old Jan 14, 2004 | 09:38 PM
hreed's Avatar
hreed
Sorry-Should have been 40 amps, not 4. But still real marginal to go to 120V.
Old Jan 14, 2004 | 10:02 PM
Matts72's Avatar
Matts72
Its about a 60" x 36".
Its also a thousand watts, and its got a built in inverter.
Old Jan 14, 2004 | 11:40 PM
hreed's Avatar
hreed
So how much will the built in inverter put out? You need to know the voltage , cycles, amperage and duty cycle.
Old Jan 14, 2004 | 11:43 PM
Matts72's Avatar
Matts72
I will have to look tomorrow, its in the basement, and I am scared of the dark.
i honestly don't even know if the thing works, i looked at it today, and I don't really know what the stuff means. I am gonna see about selling it, more panels are freaking expensive, more than the electricity that I would use for the rest of my life, seems that way anyway.
Old Jan 15, 2004 | 01:16 AM
ivanribic's Avatar
ivanribic
Used panels in good condition average about $2 per watt. Brand new run as high as $4 (my parents own an alternative energy business). If you're far from power it's often less expensive to set up your own equipment than it is to have your power company bring a line in. These panels also work out well for people who want a backup power supply, incase of a power outage. But you do have to have a battery bank to use them and you'll need an inverter as well. It can get to be quite expensive.
1000W panel is huge, you could get some good money for it. If you don't need your own private power supply I'd sell it. If you're interested in setting up a self standing power supply check out my dad's site. He's got all the info on it: http://www.windandsolar.com/solarpanels/
plumber01
Dec 23, 2011 12:17 AM
rhw
Sep 6, 2007 10:43 PM
rhw
Sep 3, 2007 10:05 AM
redplow
New Member Introductions
Jan 31, 2007 03:55 PM
Nutter
Mar 29, 2003 09:35 PM
