HELLO ELECTRICIANS
It's an old federal, She is staying with her husband in Rehab from knee surgery on both knees until about 3 more weeks, so All my advice needs to come fast if possible.
I found this one (I want to go to 200 amp box so we can get the service changed later) But as it sits right now, there is no disconnect to the house... Yes that's right NO DISCONNECT So I'll be working with the meter pulled out (I'm sure I'll have to call the Elec. Co. to have them pull it so she doesn't have a fine.
the only thing that worries me about this box is the aluminum bus bar. She has copper wiring, but I think they pushed each breaker its currently on to the limit. Will aluminum just melt it say something get over loaded and arcs on it, or should I just go with the one that has copper.
Plus I'm sure I'll have more questions later. my dad who is an electrical engineer is flaky as hell and was supposed to call me last weekend to help me out, but he is to unreliable for me to wait on him.
thanks guys any help is MUCH APPRECIATED!!
200 Amp 40-Space 40-Circuit Type BR Main Breaker Load Center Value Pack-BR4040B200V at The Home Depot
If you have some idea of how much total load they're putting on that panel and, if it's under 200 amps, then I'd say the panel you're looking at is fine.
thanks for letting me know that one may work tho, and you think it being aluminum is ok too
I replaced a panel a few years back that was so old, it didn't have breakers - it had pull-out fuse blocks. The homeowners added more circuits to the panel than what it was designed for - literally - there were blocks with multiple circuits tied into them... Some of the wiring had overheated and cooked off the insulation near the block terminals, but the bus bars were still fine...
Good luck with that project and, be safe
Here in my state we have to give a reason for wanting our meter pulled. If the electric co-op knows you are putting a 200 amp panel on the old 100 amp service, they will reserve the right to shut off your service until you get it installed per the NEC...
Anytime a panelbox is upsized the service has to be upsized to match it. To put a 200 amp load center on the existing 100 amp service conductors is against the code and I know you say it is temporary. I have seen electrical temporary projects end up years in progress. ...
You will be putting your MIL homeowners insurance in jeopardy also by changing a panel box out without inspections or servcie upgrades. God forbid, but if a cat turns a candle over and sets the curtains on fire, the fire marshall will look for electrical problems as soon as he shows up.
Sorry for the downer post, be safe...
thanks for the replies also guys
And If I have to change the service, I may get someone for that part.(may my butt, I will! )
