Low heat Problem
Old Jan 20, 2004 | 10:35 AM
Spectramac's Avatar
Spectramac
If air blockage was a problem you would have low fan force. Well?
Going back a few posts, if your water pump is loose, get it off there before it breaks the shaft and takes out that spendy radiator!
Old Jan 20, 2004 | 05:52 PM
MRZ's Avatar
MRZ
Originally posted by pnose
Never suggested removing it,just said to look for leaves and such blocking the air from going through it under the intake for it,which is under the windshield.Pop off the wiper arms and remove the 8(i think)screws,and take a look.
We are both on the same page I think.
Let me try that again- how are parts priced for your truck up there?
Old Jan 20, 2004 | 09:02 PM
loudwayne's Avatar
loudwayne
I got the waterpump on order from I.H. dealer,First they qoute me 235$Cdn.for new125Cdn$ for a reman. I op to go new & he says thay don't have them for 92-94.Just a reman.
Go figure!
Yes. I'm worried about that RAD yet it looks green & ready for an R&R. That pump started leaking just a mist when its first started till warmed up not a pretty site,-20 at 5:00a.m. & green fluid drips in the fresh snow.!!
Lord ,pity a poor boy!!
Old Jan 20, 2004 | 09:53 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Yeah, that little wimpy fan makes an awful big hole in the radiator. I had a pump changed and they did not get the fan on tight, on deceleration the fan spooled off the stud and went through all three cores of the radiator with two blades. Got the condensor for the AC to. Talk about an expensive looking sight. Glad someone else had to pick up that tab.
Old Jan 21, 2004 | 08:28 PM
loudwayne's Avatar
loudwayne
Dave S.
By the luck O' the Irish, Water pumped seize to-day going around a stopight in my locale.Felt the powersteering stop cold & knew somethings just happendNo nosie & the next parking lot she dropped her "cookies" from the seal chewed.
A call to a constant bud & Iw as at the shop in 20mins.Being decent, I returned to soak up my toxic spill" & got the 'H' out thar!!
Lucky poor boy didn't hurt a thing & was close to home with help nearby.
Helps to pray for the Best & keep on Truckin!!
DetailerDave
Aug 3, 2014 08:15 PM
77-250
Dec 14, 2010 11:01 AM
Fords412
2004 - 2008 F150
Nov 17, 2010 12:50 AM
torrexx42
1997 - 2003 F150
Jul 28, 2007 05:21 PM
