Piston slap anyone??
Old Jan 14, 2004 | 09:55 AM
oldstylefseries's Avatar
oldstylefseries
Fellas,
I'm starting to notice what I think sounds like piston slap on my motor when I start it up on a cold morning (teens or lower for temps). Just wondering if anybody else is experiencing this phenomenon.
Old Jan 14, 2004 | 10:24 AM
MustangGT221's Avatar
MustangGT221
Moved to appropriate forum.
Old Jan 14, 2004 | 11:27 AM
RTM's Avatar
RTM
If you only hear it at start up then you have a bad bearing. If it's there most or all of the time then you may have a bad wrist pin or bad piston. Does it make noise when warmed up and you free rev it?
Old Jan 14, 2004 | 12:35 PM
f100guy's Avatar
f100guy
i have a mustang that does it now. well i was told it was a piston skirt broken or a slung bearing. it is a 5 spd when i push the clutch to shift the gears you can hear it and then it quiets down. you can have it idleing and hear it barely and all of a sudden you hear a knock and then it sounds like it was before. i was told by 2 mech. that it was a slung bearing.
Old Jan 14, 2004 | 03:55 PM
RTM's Avatar
RTM
A spun bearing will more than likely knock all the time and it's not a good thing if it is spun. Either way you have a very serious problem and it should be taken care of. Its also hard to determine the problem with out really hearing it first hand. good luck
Old Jan 14, 2004 | 06:34 PM
f100guy's Avatar
f100guy
ok update on the stang. it just got way worse today while going to the mechanic. and yes now it does it all the time it sounds like a helicopter going down the road at 25 mph. good thing it did not throw a rod. i was told today that it could be also a rod bearing.
Old Jan 15, 2004 | 02:11 AM
scroob's Avatar
scroob
Sorry, but I'm going to have to disagree with this. A bad bearing knocks all of the time, and maybe worse when the engine gets hot and the oil is thinner.
Piston slap occurs when the engine is cold, and goes away when the engine warms up. This is because the aluminum piston grows more than the cylinder walls with heating, and the slack is taken up.
An engine can run a long time with mild cold piston slap, but it will eventually get worse, and will at some point bust a piston skirt.
Old Jan 15, 2004 | 02:33 AM
mebe2k's Avatar
mebe2k
I have an 86 Bronco with a 302 that does the same thing.. It also has alot of blowby and pumps out a little but of blue smoke when I accelerate. I thought it was a rod bearing at first but now i'm sure it's piston slap..I have no idea how many miles it has on it.. hoping to replace it with an EFI 351W soon..
Old Jan 15, 2004 | 09:57 AM
daerhldgs2's Avatar
daerhldgs2
the sounds are different - a rod has a double knock and wont run very long i.e. minutes not hours before it throws the rod while a piston slap is worse when cold and lessens as the motor warms up and has a single duller knock and may run for years.
Old Jan 15, 2004 | 05:30 PM
Greasemunkey357's Avatar
Greasemunkey357
ya i got a 302 in one of bronco's thats has a piston slap for two years and i have beat it pretty good....she's also got some oil pressure issues but i stopped worryin and just drive it .....its a ford...it'll be fine...but it does get quieter when the truck warms up..seems like u already had enough help...just wanted to throw in my 2 cents
Old May 5, 2004 | 10:03 PM
sefrlw's Avatar
sefrlw
RTM I have free rev knock
RTM I have this free rev knock that you are refering to what do you think it is?
Old May 6, 2004 | 08:46 AM
daerhldgs2's Avatar
daerhldgs2
Probably piston slap. A rod would be out of the block by now , when rods get loud enough to hear they don't last long, minutes not hours and days, a wrist pin has a sharper sound and will knock for a long time.
Old May 6, 2004 | 11:26 AM
f100guy's Avatar
f100guy
when i got my 95 mustang 15 minutes after driving it home, it developed a knock. it would do it right when you push the clutch in and when at higher rpms. then it got way worse when i tried to do a burnout, it was loud all the time after that, you could probably hear it a mile away. i was scared to drive it over 10 while going back home. but when i brought the new motor home to install, i decided to try to blow the motor. i got op to 60 for a while and it was knocking away big time. when i took the pan off to see what it was, i found that number 3 rod was the problem, i can't find the bearing in there at all. i did not throw the rod either. that motor looked like somebody just rebuilt it. every gasket was brand spanking new and it was very clean, just a bad rebuild.
Old May 6, 2004 | 03:26 PM
312's Avatar
312
a lot of 302 knock at start up is main bearings.mine knocks like hell till it gets oil.
Old May 6, 2004 | 04:00 PM
RTM's Avatar
RTM
Well I would take a piece of wood and try to pin point the noise if you really want to know what it is but when there is that kind of noise it can only mean something is wrong so at this point you drive it until it breaks or you replace the engine now before it leaves you stuck some where.
Even if it's a rod bearing the rod will more than likely need resized which requires you to remove the complete piston and rod together.
If its a main bearing then you may get away with turning the crank and installing new bearings.
Just remember if it is something you can save now driving it longer only increases the chances of a major fix and not a simple one and even simple fixes are some times just a band aids.
