Vibration
Old Jan 14, 2004 | 09:42 AM
harold31816's Avatar
harold31816
Vibration
I took my F350 King Ranch with 2800 miles to my dealer with the following complaint:
Truck has Moan/Drone/low frequency vibrations at idle and between 1500-2100RPM. My legs continue to quiver for a period of time after I exit the Truck because of these vibrations.
The General Manager and Service Manager called Ford’s tech hot line and were informed that Ford was aware of this problem as outline in Broadcast Message 0405 and went on to say that some drivers feet
were being put to sleep by these vibrations.
Ford also stated that the addition of three more fins to the Turbo
Blade and a new Turbo mount that they had installed on all new
6.0L engines beginning the 1st of October 2003 had failed to eliminate
this problem. Ford‘s Tech also said not to do anything to my truck
for two week because they could possible have a solution for the
problem at that time.
I purchased the truck on October 14 2003.
The engine has a build date of 7/25/2003. My VIN is 1FTWW32P14EA20805 Can anyone tell me what RC# I have?
Old Jan 14, 2004 | 11:04 AM
emtabmm's Avatar
emtabmm
Re: Vibration
Originally posted by harold31816
A: Truck has Moan/Drone/low frequency vibrations at idle and between 1500-2100RPM........Ford was aware of this problem as outline in Broadcast Message 0405.....Ford‘s Tech also said not to do anything to my truck for two week because they could possible have a solution for the problem at that time.
B: Can anyone tell me what RC# I have?
a: All very true...
b: RC4
Old Jan 14, 2004 | 12:55 PM
My4x4Toy's Avatar
My4x4Toy
I have the same problem. I feel it in the floor and the steering wheel. They can't fix it soon enough for me. Other than that the truck is great.
Old Jan 14, 2004 | 01:13 PM
emtabmm's Avatar
emtabmm
Special service message
16884 2003 SUPER DUTY F-SERIES, EXCURSION 6.0L - MOAN/DRONE BETWEEN 1500-2000 RPM
SOME 2003 EXCURSION AND SUPER DUTY F-SERIES EQUIPPED WITH A 6.0L DIT MAY EXHIBIT A MOAN/DRONE NOISE AND TACTILE VIBRATION BETWEEN 1500-2000 RPM DUE TO TURBOCHARGER MOUNTING COMPONENTS RESONATING AT THE ENGINE FIRING FREQUENCY. ENGINEERING IS INVESTIGATING POSSIBLE SOLUTIONS. THERE IS NO SERVICE PROCEDURE AVAILABLE FOR THIS CONDITION AT THIS TIME. NO SERVICE ACTION SHOULD BE ATTEMPTED.
Old Jan 14, 2004 | 01:24 PM
RLR438's Avatar
RLR438
FOR EMTABMM
I HAVE TO GO TO THE VA CLINIC IN NEW ALBANY TOMORROW, MAY STOP AND SAY HELLO AND THANK YOU FOR ALL YOUR GOOD ADVISE ON THIS BOARD. IT WILL BE IN THE AFTERNOON. WHAT ARE ALL THE NUMBERS AND SUCH WHEN YOU HOLD IN THE ODOMETER RESET AND TURN KEY ON MEAN, IS THERE A CHART OR SOMETHING TO TRY AND FIGURE ALL THAT STUFF OUT?
Old Jan 14, 2004 | 02:04 PM
SBV45's Avatar
SBV45
Try this, I got it off another site:
-- Press and hold dash odometer button in, then turn key from off
to on. Continue to hold button while all odometer display segments
light up, then mileage shows up...then release it when the display
says "teSt".
-- Each press of the button steps through the following readings.
Values shown are with truck in park and engine off; where known,
notes describe different possibilities for readings.
GAGE - all gauge needles sweep to full range, then sweep back to low
range, then go back to current readings.
******* - all display segments on
buLb - all dash bulbs illuminated
PF 3346 - ?
SF 0E02 - ?
0017430 - ?
IgnIn b - ?
r 0302 - ?
nr 0302 - ?
EE 01 - ?
dt 3E39 - ?
CF1 b0 - ?
CF2 00 - ?
CF3 00 - ?
CF4 00 - ?
dtC - display alternates between "dtC" and number(s). Diagnostic
9201 Trouble Code. (9201 is fuel sender circuit failure!)
EnG 000 - ENG(lish) units for speed - MPH
riC 000 - (met)RIC units for speed - kM/H
tAC0000 - Tachometer - reads 625 or so when idling, but highly erratic
within a range of a few RPMs. The dash tach and AIC tach sure
do stabilize these readings before showing them to you!
F 252 - Fuel sender reading. 255 is max value, presumably 0 is min.
FP 077 - Fuel pressure? Reads steady 115 with engine idling. 171 later.
255 C - ?
oiL 234 - Oil pressure - reads 000 when idling! Another fake gauge?
062 tF - ? (possibly coolant temp in Fahrenheit?)
br 123 - ?
batt12.3 - Battery voltage - reads 13.5 when idling
rhEo FF - Dash illumination rheostat value. FF when clicked to "on"
position, 28 at dimmest position. 00 when headlights off.
Prnd 40 - Auto trans lever P=40, R=01, N=80, D=10, 3=08, 2=04, 1=02
(so port bits are wired NP-D321R )
PAr o - Parking brake: "o" = off, "g" = engaged.
door 00 - Door ajar codes. Port bits: LF RF LR RR - - - -
(Ex: 80 = Driver's door open, F0 = all 4 crewcab doors open)
(Excursion rear door bit is ???)
Stbt b - ?
CHE 02 - ? (01 when idling)
PA 80 - ? (Port A raw data?)
Pb 53 - ? (Port B raw data?) (13 when idling)
PE 1C - ? (Port E raw data?) (18 when idling, 0x when dash button is pressed)
PG 04 - ? (Port G raw data?) (00 when idling)
PH 90 - ? (Port H raw data?)
PP 98 - ? (Port P raw data?_
PS 8F - ? (Port S raw data?) (sometimes reads 9F)
Pt A5 - ? (Port T raw data?) (25 H/L off, 27 park/Hl on)
PCAn 5F - ? (CANBus port raw data?)
Ad0 000 - ? (Analog-Digital Converter input pin?)
Ad1 250 - ? (ADC input pin? 255 when idling)
Ad2 050 - ? (ADC input pin? 255 when idling)
Ad3 075 - ? (ADC input pin? 083 when idling)
Ad4 142 - ? (ADC input pin? 000 when idling)
Ad5 255 - ? (ADC input pin?)
Ad6 156 - ? (ADC input pin? 174 when idling)
Ad7 154 - ? (ADC input pin? 170 when idling)
...and then back to "GAGE" again...
backdr10
Feb 22, 2011 03:41 PM
mnm38
2009 - 2014 F150
Jan 24, 2011 10:39 PM
aortizexcursion
Aug 3, 2010 12:27 AM
nationwidepro
Jun 23, 2010 08:35 PM
AzPete
1997 - 2003 F150
27
May 27, 2007 02:05 AM
