I just bought a used 2000 F250 7.3L SWB. I was reading the manual last night and it stated that some of the Ford rear diffs came with synthetic oil installed from the factory, and that it should not be touched. How can I tell if I have such a diff?
Thanks.
Chk the tag on the diff
it will say 75w-140 synthetic
depending on whether you have a ls unit
it will have another tag that reads
3L 73 or 4L10 or 4Lxx
The L stands for limited slip
When changing the fluid in the rear dif ,you add a friction modifier to help the clutch packs not be to grabby.
You can change the fluid as often as you like just add the proper amount of additive .
This will actually keep the vss sensor clean ,which will cause less problems in the future.
The Sterling axle on all single rear wheel trucks requires synthetic fluid. The Dana axles (front on a 4x4 or rear on a dually) do not require synthetic fluid.
Originally posted by NoMo The Sterling axle on all single rear wheel trucks requires synthetic fluid. The Dana axles (front on a 4x4 or rear on a dually) do not require synthetic fluid.
i changed axle seals on a 99 dually and it took synthetic.?????????
I have checked all of the places for a code for the rear diff. No luck. It seems to run at 60 mph at 1750 rpms. Which is a little higher than the mathematical equation for 3.73 and a little lower than 4.10. Any ideas?
