Sponsored by: Real Truck
Rear Diff Question
Old Jan 14, 2004 | 07:34 AM
HDMustF250's Avatar
HDMustF250
Rear Diff Question
I just bought a used 2000 F250 7.3L SWB. I was reading the manual last night and it stated that some of the Ford rear diffs came with synthetic oil installed from the factory, and that it should not be touched. How can I tell if I have such a diff?
Thanks.
Old Jan 14, 2004 | 07:41 AM
FortyFords's Avatar
FortyFords
Chk the tag on the diff
it will say 75w-140 synthetic
depending on whether you have a ls unit
it will have another tag that reads
3L 73 or 4L10 or 4Lxx
The L stands for limited slip
When changing the fluid in the rear dif ,you add a friction modifier to help the clutch packs not be to grabby.
You can change the fluid as often as you like just add the proper amount of additive .
This will actually keep the vss sensor clean ,which will cause less problems in the future.
Rich
Old Jan 14, 2004 | 08:07 AM
HDMustF250's Avatar
HDMustF250
Thanks!
Old Jan 14, 2004 | 08:39 AM
NoMo's Avatar
NoMo
The Sterling axle on all single rear wheel trucks requires synthetic fluid. The Dana axles (front on a 4x4 or rear on a dually) do not require synthetic fluid.
Old Jan 14, 2004 | 01:02 PM
RedCrewCab4x4's Avatar
RedCrewCab4x4
I replaced my "hohum stock"diff covers with polished aluminum covers and used Redline synthetic. Worked well for me.
"Ford rear diffs came with synthetic oil installed from the factory,
and that it should not be touched."
My question would be, why not? Anyway, I'm happy with the setup I have now.
RedCrewCab
Old Jan 14, 2004 | 06:20 PM
bigdawg460's Avatar
bigdawg460
i changed axle seals on a 99 dually and it took synthetic.?????????
Old Jan 14, 2004 | 06:33 PM
92f150I6's Avatar
92f150I6
WHat would happen if you just used regular 80W90 hypoid, when it calls for synthetic?
Old Jan 14, 2004 | 06:38 PM
FortyFords's Avatar
FortyFords
well it would be real stiff in the winter like they used to be at -30 F
Its lighter in weight to help with mpg's problably
Just like our 6 speeds use ATF now!
less resistance
Rich
Old Jan 15, 2004 | 07:47 AM
HDMustF250's Avatar
HDMustF250
Thanks I was wondering why the 6 speeds used ATF.
I have checked all of the places for a code for the rear diff. No luck. It seems to run at 60 mph at 1750 rpms. Which is a little higher than the mathematical equation for 3.73 and a little lower than 4.10. Any ideas?
Old Jan 15, 2004 | 08:20 AM
FortyFords's Avatar
FortyFords
No tag under a bolt on the rear cover of the diff?
Hmm !!!!
Rich
I have a 3L.73 and stock tires v8 ,I turn 2,000 at 70 give or take a few mph's speedo's can be off
by 5 mph's
Rich
