PS Pump braket
Old Jan 13, 2004 | 07:25 PM
idealtrucks's Avatar
idealtrucks
PS Pump braket
this is about my mustang really but im sure its the same as a 302 truck. the power steering pump bolt that supposed to tighten it down to the braket was stripped out so i drilled it and put a nut and bolt in it. now i cant keep my pump belt tight for over about a week. its gets loose and starts squealing. anybody ever had this problem and got any suggestions on how to stop it??
Old Jan 13, 2004 | 09:10 PM
Lobuck76's Avatar
Lobuck76
Without actually seeing what your talking about, I'd suggest drilling again and using a bigger bolt. And make sure all bracketry is installed, meaning the little tube with the flat ends that is sometimes installed for extra support.
Well.......?
Old Jan 13, 2004 | 09:31 PM
1968stepside's Avatar
1968stepside
idealtrucks,
I know exactly what you're talking about. I had the same problem. You didn't mention this and I'm not trying to insult your intelligence, so here goes.... I removed the nut and put a lock washer on, then put the nut back on. It hasn't loosened up yet. I haven't driven it in 6 months due to major electrical and carb. problems. If that doesn't work, maybe try a locking nut on it.
Couldn't figure out how to post the picture in the thread, but I was able to figure out the gallery. I put a pic of the belt adjustment in. Yes it's the only pic I have in there right now. I'm still learning all this cpu stuff!
MilllerTime
Feb 21, 2013 08:48 PM
RustyTrustyF150
Mar 19, 2012 09:35 PM
supercabfreak
Jul 25, 2011 10:00 AM
54truck
Dec 9, 2009 12:35 PM
cbfomoco
Nov 22, 2005 02:28 PM
