Rear Air Suspension doesn't work / 2000 Model
Old Jan 13, 2004 | 03:11 PM
Tough Mama's Avatar
Tough Mama
Hi All,
Re. Rear Air Suspension doesn't work / 2000 Model
I'm a new forum user trying to figure out an alternative to going to Ford to fix... like to do myself.
I had just washed the car in freezing weather, and walla, no more air in rear the next day.
I don't even hear the air compressor motor turning on... so assume this might be the problem, but since I don't know where the motor is, I'm lost to check it out myself.
Any ideas as to problem, and or where to find compressor motor?
BTW - On/Off switch is on, and all fuses look good.
The Ch Suspension light came on once, but not again.
Thx in advance for your help.
Tough Mama
Old Jan 13, 2004 | 04:17 PM
Sturge's Avatar
Sturge
Do a search under air suspension...I went on and on a few months ago about my experiences doing this myself - even posted a how to. It's not that hard and www.strutmasters.com has rebuilt units for about half what Ford will charge. Compressor/motor is right behind right headlight.
Will be glad to help if you have additional questions but most is already here somewhere if you search for it.
Old Jan 13, 2004 | 06:12 PM
Tough Mama's Avatar
Tough Mama
Thx Sturge... yep, my search is not over. I found this site below...now I just need to find the relay switch and check the wiring there!
http://autoclinic.net/article/ford/9...ition_susp.htm
I tried to find the wire coupler as shown in the link (3 pics tgether)... no success as yet... it was a 97 model, so will have to keep looking, maybe located somewhere different.
ugh... wires everywhere.
Thx again...
Old Jan 14, 2004 | 08:39 AM
Sturge's Avatar
Sturge
Thx again...
I also had a relay fail when my compressor crapped out...It's $100 at every Ford Dealer I checked. Located forward of the right front wheel well. About the size of a deck of cards with cooling fins on it. Mine was ty-wrapped to the framework behind the bumper. Had to get at it from underneath...couldn't see it looking down through the engine compartment. Harness pulls right out with a four-wire connector.
Old Jan 14, 2004 | 12:39 PM
Tough Mama's Avatar
Tough Mama
Thumbs up
Alright Sturge...
Thx for the directions on the relay switch.
Found it, and it was a loose connection on one of the wires.
Little bit of sanding down the connectors, and we should be good for another 100k
Compressor is back up and running... and without a ford service bill!
We are ready for the 4~8" of snow dropping down on us in Grand Rapids, Michigan.
Thx, n Take care,
Todd Schlosser
Old Jan 14, 2004 | 02:55 PM
black_c5's Avatar
black_c5
I'd be wary of getting a compressor from strutmasters. After getting one from them it burned out in a month, the second one lasted about 2 weeks. The dealer said the compressor they sold me was from a car, and only after getting something from the dealer saying it was the wrong part, and returning the failed part twice, they refunded $100 of the $250 bill and the gator was down for quite some time. Thet were not very pleasant to work with and even stuck me wih add'l shipping charges.
good luck, glad to hear it was only a bad connection!
83sd
May 11, 2025 02:34 AM
Johnathan Young
May 1, 2020 06:53 PM
V8SHO
31
Oct 13, 2018 10:25 AM
Jammer-1
Jan 11, 2017 06:29 PM
Brutl_Force
1997 - 2003 F150
Dec 15, 2015 07:33 PM
