Check Engine Light
Old Jan 13, 2004 | 02:54 PM
Sturge's Avatar
Sturge
Question Check Engine Light
Light came on a few weeks ago...checked the gas cap and pulled the neg batt cable to see if it would "reboot" itself....wrong! Have not gotten my hands on a diagnostics unit yet but here's the symptoms I have noticed:
Cold engine - everything is normal, starts fine, idles smooth
Warm engine - on highway everything is normal, runs smooth
EXCEPT...when I pull up to a light with the brake on and tranny in "drive" the idle begins to wander. Cycles from normal idle down to about 500rpm about once every second. If I leave it in drive it will stall. Starts right up every time and when I pull away from light it's fine until the next light.
In the meantime, I have been putting the tranny in "neutral" when pulled up to a light to take load of the engine and it keeps it from stalling.
Any ideas?
Old Jan 13, 2004 | 03:35 PM
DN27's Avatar
DN27
Go to this post and I think you will find the problem is the same as yours. It's also an easy fix.
intermit. rough idle, check engine w/ P0171 & P0174 codes
Old Jan 13, 2004 | 03:49 PM
tsdrallyer's Avatar
tsdrallyer
Check IAC and EGR and PCV valves for correct operation. Also, check fuel pressure at the engine, because pump could be going bad.
Old Jan 13, 2004 | 04:20 PM
Sturge's Avatar
Sturge
Thanks but what post are you saying I should go to??
Old Jan 13, 2004 | 04:43 PM
DN27's Avatar
DN27
That is the name of the post you can just do a search for rough idle and it will be the first or second one that comes up. I had the same problem with my 98 expy and had it fixed in 10 minutes. It's a broken vacuum line and the part number is in the post.
Good Luck
Old Jan 14, 2004 | 08:41 AM
Sturge's Avatar
Sturge
Good Luck
You da MAN! Thanks!
Shernius
1997 - 2003 F150
Oct 27, 2013 06:02 PM
radco99
May 4, 2011 09:58 AM
sixamskier
Sep 30, 2009 06:33 PM
warlord raven
Dec 26, 2003 05:32 PM
