Old Jan 13, 2004 | 12:31 PM
hotrodfeguy's Avatar
hotrodfeguy
2.3/2.5
Does anyone know the bore stroke for these two engines?
Old Jan 14, 2004 | 10:15 AM
StockRanger's Avatar
StockRanger
Cylinder bore is the same for the two engines. The 2.5 is just a 'stroked' version of the 2.3L. Not positive on the exact sizes. Heads are the same and interchangeable, but pistons, rods and the crank are not.
Old Jan 14, 2004 | 11:29 AM
hotrodfeguy
So a guy could get a 2.5 from the yard and bolt it in.
Old Jan 19, 2004 | 11:53 AM
StockRanger
If your talking engine swap....abso-f***ing-lutely. Otherwise you'll be re-building the bottom end.
Old Jan 28, 2004 | 08:17 PM
rick e foster's Avatar
rick e foster
bore and stroke
according to chiltons bore/stroke 2.3 is 3.78x3.13. 2.5 is 3.78x3.90.
Old Jan 29, 2004 | 11:37 AM
StockRanger
rick e, that 2.5 stroke sounds a little too big. Since the 2.5L is only about 10% more than the 2.3, that 2.5L stroke should be around 3.4??".
Old Feb 1, 2004 | 10:15 AM
Nightrain's Avatar
Nightrain
Yeah,a 2.5L block is the same as the 2.3L if I'm not mistaken.You can get a 2.5L Stroker crank for your 2.3L or have your stock crank ground to the 2.5L's specs,bolt in your old rods and pistons,and there you have it...A 2.5L or a stroked 2.3L.
Now,for your questions:
2.3L -
Bore:3.780
Stroke:3.126
2.5L -
Bore:3.780
Stroke:3.401
There's your specs .
Nightrain
Old Feb 2, 2004 | 09:59 AM
StockRanger
UH UH! You can't re-grind a 2.3L crank to get a 2.5 stroker, physically impossible. The rod bearing races are farther off the crank centerline (.275") thus giving the extra stroke length. Also the piston compression height is different between the 2.3 and 2.5 (to keep compression down). Sorry, if you want to stroke it, you are looking at replacing the crank, rods and pistons.
Old May 13, 2004 | 02:09 PM
lil cadence ranger's Avatar
lil cadence ranger
StockRanger, I am replacing the motor in my ranger, it is a 2.5L. I have access to several 2.3L blocks, can i take a 2.3l and biuld a 2.5L using the parts from my motor?
Old May 13, 2004 | 02:34 PM
bobracing's Avatar
bobracing
2 different blocks
There are two different blocks that you have to be aware of:
1. 2300 large journal (beginning till about 89)<O
2. 2300/2500 small journal (89 up)<O</O
The small journal crank (2300) is also about 3.5 pounds lighter too.</O
http://4m.net/forumdisplay.php?f=38
This is a racecar forum but has lots of info on 2300/2500, do a search and you will have most of your answers on 2300/2500.
Also Race Engineering (www.raceeng.com) has some inserts to fitting a small journal crank into a large journal block. From what I've read there has been different degrees of success but that was in race cars.
If you look in the catalog section they will have some tech info on rod lengths.
James
Old May 14, 2004 | 12:49 PM
StockRanger
lilcadence, bob's correct. As long as the 2.3L blocks have the same journal size as your 2.5L crank, you should be able to use them. Only things I would use from your 2.5 would be the crank, rods and pistons. This will increase your compression ratio, so be mindful that you will probably need to run premium gas to avoid detonation.
Tombonetoo
Testing.....
Feb 20, 2017 04:03 PM
IB Tim
Oil & Lubrication
May 15, 2013 02:22 PM
Franklin2
Nov 12, 2001 02:38 PM
redbronco2
Bronco II
Jul 27, 2001 01:48 AM
jtuck2
Electrical Systems/Wiring
Dec 23, 2000 09:25 AM
