Sponsored by: Real Truck
cruise control 2001
Old Aug 12, 2002 | 12:37 PM
usmc1775's Avatar
usmc1775
cruise control 2001
has any one had a problem with the curse control surging on them between the speed of 68 to 72 or at any speed. I am having a fight with ford about this, i am almost sure that this is a factory defect. Thank you all in advace for your hepl.
Usmc1775
2001 pds crew 4x4
Old Aug 12, 2002 | 01:51 PM
NoMo's Avatar
NoMo
cruise control 2001
YES! Do a search and you should find a topic (or two) where we've discussed this issue. Both my '00 F250 (now gone) and current '01 F350 surge terribly at the same speeds you state.
Old Aug 12, 2002 | 03:13 PM
CEEJR's Avatar
CEEJR
cruise control 2001
Yeah my 2001 SD did the same thing. I mentioned it to the service dept. and was told that there is a service alert out for the problem not a TSB. The problem is caused by an ABS sensor. I no longer have the truck and I never did get it fixed. I was also told that it will do it a 48 mph and something like 97mph. Your Ford dealer should have info on this matter. My 02 dosen't do it so I guess they have corrected the problem.
Chuck
Old Aug 12, 2002 | 09:45 PM
daimon1054's Avatar
daimon1054
cruise control 2001
I thought it was only mine it surges at the exact same speeds
Old Aug 13, 2002 | 07:31 AM
benr0's Avatar
benr0
cruise control 2001
I have the same problem, Same story from dealer. I did find a perm fix though. Don't set cruse at 69 or 70
Sorry, I know how irritating it is at times. If anyone gets at real fix it seems plenty of others would like to know.
Old Aug 13, 2002 | 09:39 AM
NoMo's Avatar
NoMo
cruise control 2001
That's been my solution too. I'm afraid to let the dealer "fix" something that isn't badly broken. However, it does seem to be getting worse lately.
Old Aug 13, 2002 | 02:49 PM
daimon1054's Avatar
daimon1054
cruise control 2001
she went in the shop today for other things but I asked them to check this I will let you know what comes up.
Old Aug 14, 2002 | 07:31 PM
daimon1054's Avatar
daimon1054
cruise control 2001
I was told they never heard of it ther is no TSB my dealer is going to try changing the module. They did not have one so I will wate till tomorow.
Old Aug 15, 2002 | 07:09 PM
4x4x4x4's Avatar
4x4x4x4
cruise control 2001
Old Aug 15, 2002 | 10:17 PM
daimon1054's Avatar
daimon1054
cruise control 2001
they changed some module (do not know what)and it did not work so the dealer ordered an ABS module. May find out tomorow if the part comes in.
Old Aug 16, 2002 | 08:27 AM
FortyFords's Avatar
FortyFords
cruise control 2001
Guys try this,clean the vss sensor in the rear dif,it gets dirty
causes this sometimes,don't ask me why its only at those speeds though
seems strange but it fix it on my 02.
Rich
Old Aug 16, 2002 | 04:33 PM
daimon1054's Avatar
daimon1054
cruise control 2001
It's fixed chanded the ABS module.
There is a service advisory or some such, no TSB however I asked the dealer what a person did if they were out of warranty? He said that because the notice from ford that it is a warranty covered item.
Old Jan 20, 2003 | 08:23 AM
benr0's Avatar
benr0
Cool cruise control 2001
Ok, got mine fixed as well. Took dealer over a week to fix, they twice ordered the new part for a 4WD. Mine is 2WD, I almost didn't want to let them install it!!
Anyway my part # is
SP0 1C3Z 2B373 AB
Description - Module ASY-BRK A/LOC
No surge here!
Old Jan 20, 2003 | 11:43 AM
hookspacken's Avatar
hookspacken
cruise control 2001
I have had the same problem, but have been dealing with it just by not setting the cruise at that speed. I am afraid that if I bring it in for that, that I will be opening a can of worms and make bore problems then i would solve.
Old Jan 21, 2003 | 03:27 AM
wgm114's Avatar
wgm114
cruise control 2001
I am having the same problem. Great stuff you guys!
