emrgency brake lockup
Old Jan 12, 2004 | 11:08 PM
ford55truck's Avatar
ford55truck
Maybe I can get some insite again.
Park my F100 in front of the garage and it has a slight incline. Went out today to go to the store and found the emergency brake locked up. Linkage(s) are all connected from the brake handle all the way through the drums. Pulled it back up in the driveway and the rear right tire left some rubber on the concrete driving it up. I don't know which rear wheel drives either. Anybody have this problem?
I had set the emergency brake when I parked it before going out today and it seemed to happen when I released the brake.
Would be grateful for any info.
Thanks, Tom
Old Jan 12, 2004 | 11:55 PM
MO51's Avatar
MO51
Park brake lockup
If your right rear wheel was spinning, then it is likely your parking brake is "locked up" at the left wheel. Are you in a cold climate? They can freeze up. My impulse would be to anoint all the cables and their sheaths with WD-40 or similar penetrant. If that doesn't work, it's time to pull the left drum, and see what falls out.
Old Jan 13, 2004 | 11:17 AM
ford55truck
MO51
First, thanks so much for the reply.
I guess it is safe to assume the rear right is the drive wheel. I should then be able to just jack up the rear left, on an uphill incline with blocks, and see if the drum will come off. I'll let you know what I find and again thanks so much.
Tom
PS: amazingly enough I am in So. Calif. by the ocean and it has gotten down to 32 some nights but only for an hour or two and then 68-70 during the day.
Old Jan 13, 2004 | 05:34 PM
mtflat's Avatar
mtflat
Both rear wheels 'drive', just one at a time. Be careful to block it securely so it doesn't roll, and don't trust the jack - use blocks or jackstands.
If you can't get the drum off, there is a hole in the bottom of the backplate where you can get to the adjuster. Using 3 hands and 2 screw drivers you can back it off and release the tension of the brake shoe on the drum. (use one to push the keeper away from the star wheel and use the second to back off the star)
If that makes no sense, a good repair manual should show it.
I wish our temp would get UP to 32*
GreatNorthWoods
Jul 17, 2011 02:21 PM
bc11
Jul 28, 2009 06:56 PM
CharGriller
42
Feb 28, 2009 08:08 PM
tip49
Aug 21, 2007 02:30 PM
RVOOPS
Jul 8, 2007 07:47 PM
