Sponsored by: Real Truck
rough idle when start up!!!
Old Aug 15, 2002 | 10:23 PM
redranger1's Avatar
redranger1
hey guys. i have an 02 with the 5.4. today when i picked it up from the glass shop and started her up it idled really really rough! almost like it was missing on 2 or more cylinders. it happened as soon as i started it up and it was rough enough that it vibrated the truck pretty bad. the rpm also fluctuated between 500-1000 rpm. i sat let it idle fer a few minutes and then reved it up slightly and it didnt seem to help/hurt it anymore. after about 5 minutes of idleing it slowly cleared up and quit all together. this is the second time that this has happened and now im startin to get a bit worried. i wondered if maybe it was somethin in the ignition mudule, but it doesnt make since that it would fix itself. any other suggestion???
-nathan
Old Aug 16, 2002 | 05:24 AM
chuckwpb's Avatar
chuckwpb
Did they by any chance unhook the battery? Sounds like your PCM may be 're-learning' your trim settings. It should be gone after a couple of warm-up cycles, if that's the case.
Old Aug 16, 2002 | 11:01 AM
warmdye's Avatar
warmdye
[updated:LAST EDITED ON 16-Aug-02 AT 12:01 PM (EST)]mine has done this a few times too. I think it might be moisture on those coil pack things.
Old Aug 16, 2002 | 06:28 PM
thewhiteford's Avatar
thewhiteford
Yeah, sounds like a coil pack thing. My friend had a 99 F250 LD with the 4.6 that had really rough idle. Turned out to be a coil pack. Those things really should be shielded better. There was a major problem with coolant leaking from a hose located above the #4 coil on earlier half-ton models. Maybe the heat from the engine evaporates whatever moisture is there and that's why the rough idle disappears after a few minutes.
Old Aug 16, 2002 | 06:56 PM
redranger1's Avatar
redranger1
no, the battery was not disconnected. ill have to check into that other possibility. thanks fer all of the replies.
-nathan
Old Aug 16, 2002 | 09:42 PM
trip's Avatar
trip
My truck,(2002f250v10430gear4x4) has done this about a half dozen times. I would like to know why also. I lease my trucks for two years and have found that finding the problem with little things like this from the mechanics at the dealership is like pissing in the wind. If the problem can't be recreated there is no problem. The best answer for me is turn the truck in after 2 years and the problem is no longer mine. Please let me know if you find the answer.
I do love these new sd trucks. I have found the best fix for that once in a blue moon rough idle is to turn the truck off and restert it. that has worked for me every time. Bruce
Old Aug 16, 2002 | 09:49 PM
krane operator's Avatar
krane operator
Mine would do that time to time, but later on it turned out to be the air idle control valve. Just my two cents.
1999 dark torredor clearcoat mettalic xcab
02 fog lights
02 cup holders
02 tow hooks
02 6cd indash
lund bugshield
diamond blue lights
k-9 alarm:-) :-)
Old Aug 16, 2002 | 10:16 PM
4x4x4x4's Avatar
4x4x4x4
I would also look into the IAC valve.
Old Aug 17, 2002 | 07:20 AM
infinity's Avatar
infinity
Just a thought. The PCM (Powertrain Control Module) throughs alot of fuel at the system when you first start it up. If they moved the truck around (very short trips) it might have soaked the combustion chamber to the point of a mis-fire condition. I have an 02, V-10, SD, F-350 and a 97, 5.4, Expedition. When I go camping and if I move them around alot at the campground (10 second trips) they will flood themselves and mis-fire the next time I start them up. I do not know if my condition applies to yours, but my 2 cents.
Old Aug 17, 2002 | 08:20 AM
slpj's Avatar
slpj
Milly1219
2004 - 2008 F150
Jun 11, 2014 09:48 PM
minitrk
Oct 19, 2012 08:35 AM
richard stone
1997 - 2003 F150
Feb 2, 2011 04:59 PM
CJK440
1997 - 2003 F150
Jan 31, 2006 01:08 PM
