90,000 Service needs???
Old Jan 10, 2004 | 02:58 PM
Jordanz's Avatar
Jordanz
Question 90,000 Service needs???
I've got a 91 Explorer Sport. It is at 90K and running rough. I have received a few estimates, but all are too expensive for me at this time since I am recently unemployed.
Does anyone have an idea of the most basic service needs at 90,000?
I want to keep the engine in good running order, but things such as "tire rotation" I'm sure can wait a few months.
Anywhere I c list of 90,000 serive needs and anyone have any suggestions as to the basic service needs I can request to be done so I can reduce the cost while still maintaining the good running order of the truck>
Any help would be greatly appreciated!
Thanks .
Old Jan 10, 2004 | 04:20 PM
dogman's Avatar
dogman
Jordanz
Welcome to FTE
plugs, wires, filter,PCV, and a oil change would be a good start and work from there. Would look at getting the tranny fluid and filter change soon. cost around 100. or less. tranny rebiuld around $1400.00 you don't want a rebiuld.
Old Jan 10, 2004 | 04:25 PM
Jordanz's Avatar
Jordanz
Thanks. I appreciate your reply.
Well, I can pass on the oil change since I do the JiffyLube appointment every 3K and just had it done 2 weeks ago. Maybe I can do the tranny fluid and filter change instead.
What did you mean by "tranny rebiuld around $1400.00 you don't want a rebiuld."?
Thanks again.
Old Jan 10, 2004 | 06:40 PM
dogman's Avatar
dogman
A buddy of mine had the tranny crap out becouse he did not service the trans. It's to be done ever 30,000 mile */-. Just did mine and my miles per gallens whet up. the trans. run around 1400.00 to rebuild a cost you don't wont when looking for work.
Has your trans. ever been service?
Old Jan 10, 2004 | 08:15 PM
96explorereddieb's Avatar
96explorereddieb
Also run Seafoam a couple of times and your roughness should be smoothed out...
Old Jan 13, 2004 | 06:02 PM
Jordanz's Avatar
Jordanz
Seafoam?
Billy, Thanks for the reply, but what in the heck is "seafoam"? Where do you get it and how is it used?
Thanks!
Old Jan 13, 2004 | 06:17 PM
96explorereddieb
No problem bud. Seafoam cleans whatever it touches in the engine. It cleans different areas depending on where you pour in. I got mine at Car Quest. I'm sure they're available at Napa too but double check.
I think you're better off by sucking it through the PCV valve than the brake booster line because you may not know what will happen if you didn't clamp the hose tight enough once you're done. Run it a few times and your engine will be like brand new, I promise. Good luck!!
Old Jan 13, 2004 | 06:19 PM
Jordanz's Avatar
Jordanz
Thanks Billy!
Your suggestions are much appreciated.
50f6
Jul 29, 2014 01:25 PM
obsidianspider
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
May 19, 2013 05:23 PM
mnmwhit
Feb 6, 2010 09:45 PM
LambertMorgans
Feb 22, 2009 12:02 PM
bmartin30
1997 - 2003 F150
Apr 14, 2004 11:52 PM
