Service Engine Soon Light
Old Feb 22, 2009 | 08:22 AM
LambertMorgans's Avatar
LambertMorgans
Hi all,
New to group , good to be here looks like a ton of help here, I'm sure to reference this group before any other source!
My question,
When you get a SES light and have fixed the problem, do you need to reset these codes via a OBD computer, or will the light automatically go off on its own?
2000 Expedition E.B 90,000 miles
Thanks a ton
Old Feb 22, 2009 | 08:41 AM
Modified 99's Avatar
Modified 99
Disconnect your battery for at least 15 minutes or go to O'Reilley or Auto Zone, they will reset it for you.
Old Feb 22, 2009 | 09:07 AM
cr_expyeb98's Avatar
cr_expyeb98
Originally Posted by LambertMorgans
Hi all,
My question,
Thanks a ton
It needs to be reset, and most auto parts stores will no longer do that. You could disconnect the battery, but it is recommended that you pull the fuse to it.
Old Feb 22, 2009 | 12:02 PM
LambertMorgans
Thanks,
I simply changed oil and air filter, since I just bought it, and wanted to get it up to date to my service records.
While changing the air filter, I must have pulled a vacuum line just enough to set off the P0171,P0174 Too Lean codes.
I went throught and snugged everything up, reset computer, and just got back from a 45 mile drive and no SES light. Hopefully this did it!
Thanks again!
FordBlueHeart
Nov 28, 2016 12:41 AM
1978crewcab
Texas Chapter
May 17, 2016 11:40 PM
HIDextra
Vendor Specials, Discounts, Product Announcements & Group Buys
51
Jun 11, 2015 05:46 PM
sunuvabug
May 25, 2013 04:10 PM
