Cam Removal w/o pulling engine?
Old Jan 10, 2004 | 11:58 AM
Stark's Avatar
Stark
Is it possible to pull the cam out of my 302 ('74 F100 Ranger XLT)without pulling the engine out? What all would this involve? Pulling the whole front clip off? Would it be better just to pull the engine out instead?
I don't have garage space left (my Fairlane is in there), and my driveway is at a slope and its mostly gravel, so trying to maneuver a cherry picker would be impossible.
Thanks for any suggestions guys.
Old Jan 10, 2004 | 12:26 PM
F150daniel's Avatar
F150daniel
take the grill off and the radiator and ac thing out and you should be able to do it.
Old Jan 10, 2004 | 12:29 PM
biz4two's Avatar
biz4two
Yes...it should be possible. I did it on my '76 390FE engine. What is involved (besides removing the obvious...water pump...etc.) the radiator comes out. Now all you have to do is loosen the grill inserts (total of about 8 screws). After loosen the grill support (vertical support) and slide it over. You may not even need to loosen the grill support...as the 302 is smaller and may allow the cam to go in with just enough space.
Good luck!
Old Jan 10, 2004 | 04:46 PM
fozzy's Avatar
fozzy
Just break it apart to get out, then hammer a new one in. LOL
seriously, I did it w/out removing engine. radiator has to comeout. Its probably time for a new thermostat and coolant anyway right?
Old Jan 10, 2004 | 05:37 PM
ncl's Avatar
ncl
My 77 has a 400 and all I had to do was remove the radiator didnt have to touch the grille.
Old Jan 11, 2004 | 04:46 AM
Stark's Avatar
Stark
Thanks for all the tips, fellas. I might just try that next weekend!
Old Jan 11, 2004 | 04:13 PM
supercab78's Avatar
supercab78
Just don't do what a guy did to a 64 chev 409 SS convert. Back in the mid 70's a guy cut a hole in his grill because he couldn't get his cam out. It must have been to much work to pull the grill.
Old Jan 11, 2004 | 05:03 PM
2020's Avatar
2020
I had to change the Crane cam to milder stock 351CJ cam after I put the 351 Cleveland in my 79.I took the radiator out and left the AC condensor there.It was loose and I could move it,but I didn't have to take it out.
93F22A6
Sep 6, 2009 02:27 PM
pipman76
Aug 29, 2009 02:54 PM
justforkicks
Mar 25, 2009 09:33 AM
Raptor119
Oct 16, 2007 08:51 PM
w-i-l-l-i-e
Sep 17, 2006 09:03 PM
