302 question
Old Jan 10, 2004 | 09:31 AM
RichardMaerz69's Avatar
RichardMaerz69
302 question
engine idle jumped about 300 rpm and a metalic rattling sound
apperd in exhaust manifold and died possible valve problem.
Old Jan 10, 2004 | 11:12 AM
bdonalds's Avatar
bdonalds
So uhhhh....what's your question?
Did you search this forum? Anyway, check out these recent threads. Two of them are regarding bent valves, one is a rattling caused by a crack in the header.
https://www.ford-trucks.com/forums/s...hreadid=188690
https://www.ford-trucks.com/forums/s...hreadid=188352
https://www.ford-trucks.com/forums/s...hreadid=185574
Bryan
Old Jan 10, 2004 | 11:43 AM
RichardMaerz69
sorry about that,I was just wondering if a bent valve would sound
like that and cause it not to start again.
Old Jan 10, 2004 | 12:01 PM
f100guy's Avatar
f100guy
no it should start again if it is just one valve hopefully you did not drop one or screw up the cam
Old Jan 10, 2004 | 12:21 PM
RichardMaerz69
tried to start it again but all it did was sputter and spit like it wanted to start but wouldn't .Not going to fix it just yet but it is
nice toknow what happend to it. Thanx for replies.
Old Jan 10, 2004 | 06:21 PM
RTM's Avatar
RTM
Bad timing chain, jumped time?
Old Jan 10, 2004 | 06:29 PM
RichardMaerz69
new timing chain and gears about six months ago. Would a cracked head cause this prblem.?
Old Jan 10, 2004 | 06:39 PM
RTM's Avatar
RTM
Not sure if a cracked head would cause these kind of a problem. i have never experienced anything like that or read about anything like that.
It may be best to remove the valve covers at this point and see what you have under there. If everything looks good pull the coil wire and crank the motor over to see if everything is moving correctly.
Never heard of a ford V8 breaking a cam but you never know. Just a thought.
Old Jan 10, 2004 | 07:18 PM
RichardMaerz69
thanx for the info will look into it.
