Modular V10 (6.8l)
Pinging V10
Old Jan 9, 2004 | 06:41 AM
jade97's Avatar
jade97
Pinging V10
Does anyone know if the timing is ajustable on the V10, either by 'flash' or adjustment? My truck started to ping over the last few months (while the engine is 'lugging', before it downshifts/87 octane as stated in the owners manual).
I tried buying fuel at 3 different stations (3 tankfulls per station), still pings.
Changed the fuel filter & the air filter.
The only thing that cured it was (1) tankfull of 92 octane. When that ran out I went back to 87 and......the pinging returned.
I know I can just start running 92 all the time (and releaving my bank account), but the truck is supposed to run on 87 and it did so for over a year.
The truck is a 2002 F250SD CC SB 4x4 4:30's AT with stock size 2657516 tires. Also, it doesn't matter if the AC compressor is on or off.
I want to know if anyone else had/has this problem before I inconvienience myself with the stealership (yes it is under warranty).
Old Jan 9, 2004 | 06:59 AM
Lighthouse's Avatar
Lighthouse
Mine started dioing the same thing a few months ago. I do not know if this will work for yours, but I disconnected the battery to reset the computer and the pinging is gone. These trucks have a "knock sensor" that is suppose to retard the timing when the engine starts to ping. My guess is that resetting the computer got the sensor going again. Just a theory but it worked.
Old Jan 9, 2004 | 09:36 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Like Lighthouse said, reset the computer first. Disconnect the battery overnight, and then take it out on the highway, cruise at 70+ for a 5-10 minutes, pull over, coasting all the way without hitting the brakes, then pull out slowly, speed back up to 70+, and then pull over again.
Then, MASH IT TO THE FLOOR, and go back up to 70+.
This will make the computer relearn everything and go into closed-loop ...
One thing, if it pings again soon after resetting the computer, you probably have a bad knock sensor.
Funny story: I had a dirty MAF in my '96 4.6L T-bird, overoiled K&N. Cleaned it, and according to the TSB about the fault code I got (lean bank 1/2), Ford says to get the computer to learn the MAF, I had to get onto the highway, and in 3rd gear, keep my foot to the floor for at least 30 seconds (or a minute, or something like that).
Only problem was with my Superchip and a 3.73 rear, I was doing over 120MPH before the 30 seconds were up... and they said to repeat it a few times! Mustang GT thought I was playing with him, and started to get pissed off because he was losing ground around that 120 mark... funny... t-bird was more aerodynamic than his 'stang...
Old Jan 9, 2004 | 10:56 AM
jade97's Avatar
jade97
Thanks!
I'll have to try the reset.
V10Crew's Avatar
V10Crew
Mine was pinging with the trailer behind it, did the same thing, put premium in it, pinging was gone until 87 octone was back in it, I did the computer re-set and now everything is fine. Going on around 5000mi since and still no problem.
Old Jan 9, 2004 | 11:01 AM
krewat's Avatar
krewat
Sounds like a software bug - the computer gets stuck somewhere, can't retard the timing and it needs a hard reset to get it working again.
Don't tell me Microsoft is writing the OBD II software !
Old Jan 9, 2004 | 11:13 AM
V10Crew's Avatar
V10Crew
why not, Bill Gates needs another couple Billion.
Old Jan 9, 2004 | 08:44 PM
68 351 bronc's Avatar
68 351 bronc
Krewat, were you serious when you wrote the reset procedure? unpluging over night I can understand. Getting another ticket I don't need. No Freeways in Stevens County Washington. Any other methods?
Old Jan 9, 2004 | 10:26 PM
krewat's Avatar
krewat
I wasn't kidding, but for you, just reset and drive normally. It would be good to get the computer to go closed-loop (all diagnostic tests passed) quickly, do the highway cruise, coast to a stop, accelerate back to 70MPH+, coast to stop, accelerate again. This seems to get my OBD-II vehicles to pass their diagnostics quicker than normal driving, as detailed in my '96 T-bird 4.6L manual ...
For whatever reason, for my t-bird, the TSB for a "contaminated MAF" said replace the MAF and do that "hold full throttle for 30 seconds" stuff...
I didn't mean YOU had to do it!
Old Jan 9, 2004 | 10:59 PM
68 351 bronc
Thanks for the info. we have similar trucks. mine is torador red
01 F250 V-10 auto 4X4 XLT 3.73 SC SB
Old Jan 15, 2004 | 07:07 PM
Dwinn's Avatar
Dwinn
I have also had ping problems with my 2000 f250 v10. Had the Ford dealer do the diags and they told me the ping was normal. Since I didn't buy that line, I went to the parts store to look at fuel injector cleaners. The people there said a lot of local mechanics use a fuel treatment oil from Lucas Oil. The oil actually goes in the gas tank! I tried it a couple of times and no knock, so I bought some by the gallon (much cheaper). Maybe I'll fill it up with just the 87 octane gas next time and see if it knocks. If it does, I'll try the computer reset mentioned here. If it still knocks, I'll put the Lucas Oil in again.
pidaster
Aug 30, 2011 06:43 PM
Eric K
Modular V10 (6.8l)
126
Apr 20, 2008 12:35 AM
TallPaul
Aerostar
Mar 17, 2008 02:41 PM
bullit340
Sep 9, 2007 09:06 AM
pwhopkins
May 8, 2001 10:09 AM
