efi head on carb block
Old Jan 8, 2004 | 07:50 PM
ob-4-id's Avatar
ob-4-id
Question efi head on carb block
i had a look at a donor bronco tonite, im not sure of the year(early 90's) seems to be in good condition excluding a siezed motor from overheating. my question is this, i have a 79 block in good condition, and assuming the efi head can be restored, would casting differences prevent that head from bolting onto my block? if so, would i need to modify anything more than a block off plate for the fuel pump? thanks in advance for any input/advice
Old Jan 8, 2004 | 08:38 PM
ftwfred's Avatar
ftwfred
Are you gonna use the EFI or the Carburetor for this project??
Old Jan 8, 2004 | 10:59 PM
steell's Avatar
steell
If you are staying with EFI, I don't think you will have any problems.
Old Jan 8, 2004 | 11:00 PM
ob-4-id's Avatar
ob-4-id
this would be efi if possible
Old Jan 8, 2004 | 11:21 PM
optikal illushun's Avatar
optikal illushun
http://fordsix.com/forum/viewtopic.php?t=10655
give it a good lookin over, really useful info there.
Old Jan 8, 2004 | 11:32 PM
ob-4-id's Avatar
ob-4-id
hey, thanks for the info folks. I sure do appreciate the instant response, i think tommorrow i'll have to have a closer look, i may be buying a newer bronco.
Old Mar 2, 2004 | 11:41 AM
HIGHOUTPUT's Avatar
HIGHOUTPUT
Lightbulb
"IDEA" Can i use an efi head in a carb setup to increase compression
Old Mar 3, 2004 | 05:09 AM
Ford_Six's Avatar
Ford_Six
One thing to watch for- EFI heads do crack, especially when overheated. Aside from the unfinished fuel pump hole, the blocks are the same. For a block off plate, use one for a big block chebby. Same size and bolt pattern.
You can use the EFI head on a carbed engine for higher compression, but then you have to re-curve the distributor for the fast-burn combustion chambers. A better way to go is the 240 head.
Old Mar 3, 2004 | 02:34 PM
borin&strokin's Avatar
borin&strokin
I know for a fact that the EFI stuff will work on a 79 Block and head. (or at leas the 87 EFI stuff) We put a good 79 motor in our 87 Truck when the mains started knocking. All the FI stuff stayed. A couple sensors are different, so watch out for that. The oil pan/ dipstick was different, too. We had to cut the dipstick and now it reads empty. Great joke to pull at full serve gas stations... "Check the oil, please.." And for the "block off plate" we used the fuel pump that was on it, and looped a hose from in to out. Cheers.
Old Mar 4, 2004 | 03:22 AM
HIGHOUTPUT's Avatar
HIGHOUTPUT
How do u re-curve the distributor for the fast-burn combustion chambers
do u mean reset the timming
Old Mar 5, 2004 | 11:38 AM
HIGHOUTPUT's Avatar
HIGHOUTPUT
hey Ford_Six what do u mean exactly
anybody!!!
Old Mar 6, 2004 | 06:17 AM
Ford_Six's Avatar
Ford_Six
Specifically, the base timing is the same, but the advance is slower. The max timing advance comes later than in the carbed engine. If you are using the whole EFI setup, you don't need to worry about it- the computer takes care of it, there is no mechanical or vacuum advance. With a carbed engine, though, you will need to play with the springs and weights to get it right, or just get a custom curved distributor.
Red Rascal
Feb 4, 2017 09:25 AM
abrojal
Sep 17, 2016 11:59 AM
Lagniappe
Jul 27, 2015 12:24 PM
E30tdf
13
Jul 9, 2007 01:49 AM
wantaford
Nov 5, 2004 10:39 PM
