Hi all, I need rebuilt my rear axel but I'm not sure what exactly model is it, as far as I know it seems DANA 44, it has floating axel, and use shims bellow bearings and pinion.
If someone can give me info or pointing me to some place, I really appreciated it.
It had a 3.23 originally? That's a chevy axle ratio. That doesn't sound right.
A 3.55 ratio is most commonly found in ford 8.8" axles. Although it sounds like you have a bit of a frankenstein on your hands.
A 1986 F-150 would have either a 8.8" or 9" axle in it. They're easily identified. A 9" will have a removeable third member but no inspection cover on the rear. A 8.8" axle will have 10 or so bolts holding the rear cover on. You can take the cover off and inspect the gears for wear, etc. My guess is that you have one of the two axles.
Dana 44's were never offered under the rear of any F-series truck.
1º There is inspection cover...
2º Riginal ratio was 42X13 (3.23)
3º All inside parts say DANAVEN which is the Venezuela's DANA Div.
4º This truck was made in Venezuela, so not all thinks are same as USA.
5º As I say previously I changed from 42X13 to 46X13 just replacing pinion and crown gear, not any more...
What should I messure to find that 8.9" or 9" ??? I still have the 42X13 gear set, maybe we can use it to get right identification.
What I'm looking is info regarding to how to setup the shims, preload, pinion possition and so...
Well, I'm going to look for a digital camera to take a picture, meanwhile, where can I see a DANA60 or 8.8???
There is no tag at axel, just a plate saying 3.55, 46X13. Nothing else. Door tag will not help because numeric system use here in Venezuela is diferent than USA, so there is no axel identification.
