Sponsored by: Real Truck
Problem w/ E40D trans
Old Sep 4, 2002 | 03:28 PM
Dualiedo's Avatar
Dualiedo
[updated:LAST EDITED ON 04-Sep-02 AT 04:29 PM (EST)]I had it rebuilt and had new electricals put on it from the ford shop. The problem now is that before I can drive it after it has been setting for a few days I have to let it idol a few before it will take the gear. I also experienced it when I was pulling a Car for a distance, when I got to where I was going when I put it in reverse it hesitated(slipped). I let it seat for around 3 hours and it did fine when I got ready to leave. Its a 19991 F350 Dually OD
Old Sep 4, 2002 | 08:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
First thing to check is the transmission fluid level. With the transmission warmed up and the engine idling in park is the level in the DO NOT ADD zone?
If so, check it before starting after it has set for as long as it takes to usually show the problem. If it is a long way overfilled the torque converter is draining back into the transmission. There is a check valve in the valve body that can stick and cause this. The delay is waiting for the torque converter to refill.
Old Sep 5, 2002 | 06:04 PM
Dualiedo's Avatar
Dualiedo
The fluid is ok when its running, I'll check in the morning before I start it to see what it shows. Thanks
Old Sep 6, 2002 | 09:11 AM
Dualiedo's Avatar
Dualiedo
I checked it this morning and it was way up the stick. There seems to be a mark on the stick for cold check. It was above all the writing.
Old Sep 6, 2002 | 09:42 AM
Waxy's Avatar
Waxy
Sounds like Mark nailed it on his first try. What an asset to FTE to have a guy like that around.
I guess you need a new check valve. :-(
Waxy
Old Sep 6, 2002 | 10:10 AM
Dualiedo's Avatar
Dualiedo
It has been doing it since it was rebuilt. Where is that valve. It was just rebuilt
Old Sep 6, 2002 | 04:15 PM
FortyFords's Avatar
FortyFords
The internal in the tranny,
needs to go back to the shop that rebuilt it.
Rich
Old Sep 6, 2002 | 07:27 PM
FortyFords's Avatar
FortyFords
