Oil Contamination
Old Jan 8, 2004 | 04:43 PM
BUBSDAD's Avatar
BUBSDAD
Oil Contamination
WE HAVE 3 NEW 6.0 DIESELS THAT WHEN WE HAVE THE OLD OIL TESTED THERE IS 5% FUEL IN THE OIL, FORD SAYS THERE IS NO SPEC FOR THIS. IF THE OIL LEVEL DOES NOT GO UP IT IS OK.
DOES ANY BODY KNOW OF A SPEC FOR THSI OR IF THIS IS EXCESSIVE.
I'VE BEEN TOLD BY THE SMARTEST MAN IN THE WORLD, MY BOSS, THAT IF THIS WAS A CAT DIESEL THEY WOULD SHUT IT DOWN AND REPAIR IT IMMEDIATLY.
Old Jan 8, 2004 | 06:35 PM
cdtruckn's Avatar
cdtruckn
Fuel in the oil. you better get it to a dealer that will change the injectors. My truck is in for this right now.
tell your dealer of course there is no spec. because there is not suppose to be any fuel in the oil.
Old Jan 8, 2004 | 06:37 PM
psdwanabe's Avatar
psdwanabe
Thats why you need to tell him your oil level is rising! Then they have a procedure to check it out (leaking injectors).
Old Jan 8, 2004 | 10:57 PM
steele138's Avatar
steele138
Ask Ford if diesel is a suitable lubricant; I'll bet they'll tell you no. Then ask why its ok THIER product is poisoning itself. Start your paper trail ,document everything. When these trucks run ;they absolutely scream and when they get the bugs worked out it WILL be a world beater.
Old Jan 8, 2004 | 10:59 PM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Diesels by nature will have fuel in the oil. During cold start up the rings have not expanded to a complete seal with the cylinder yet. I have no idea what the spec is, but just because there is fuel in the oil does not mean there is necessarily a problem.
Old Jan 9, 2004 | 09:58 AM
cdtruckn's Avatar
cdtruckn
Stick to gasers
ANY fuel in the oil IS a problem.
Old Jan 10, 2004 | 10:17 AM
"Luke" SdeS's Avatar
"Luke" SdeS
Fm BroncoGue
Diesels by nature will have fuel in the oil...
With considerable respect......FIVE PERCENT..fuel in the oil ? ?
Old Jan 10, 2004 | 11:25 AM
4x4Mark's Avatar
4x4Mark
According to Blackstone Labs, <.5% is the target for an engine already broken in. I've seen some report of around 2% for engines during break-in. 5% does seem high, especially if the engine is already broken in.
Old Jan 10, 2004 | 12:10 PM
dae's Avatar
dae
From what my blackstone's report shows, Fuel in Oil should be less then 2%. Below is my oil analysis on a Cummins with 1100 miles.
Old Jan 10, 2004 | 01:41 PM
"Luke" SdeS
4x4Mark & dae:
Good input, thank you.....
Very good dae.....
pelletman
Large Truck
Apr 30, 2017 02:45 PM
Tugly
Jan 4, 2013 02:47 PM
Brittany Gossett
Jun 7, 2012 07:57 PM
philwaters
Apr 4, 2010 08:26 PM
Beachbumcook
Feb 7, 2006 07:34 AM
