Common disk brake rear swaps
Old Jan 8, 2004 | 10:05 AM
svooom's Avatar
svooom
What are some of the most common disk brake rear ends that can be swapped into classic trucks. I've heard of 80's Lincolns, 90's Crown Vics, and 80's Thunderbirds. Are there any others that would do the job?
Old Jan 8, 2004 | 11:34 AM
Jag Red 54's Avatar
Jag Red 54
My 54 has a disk brake rearend out of a 78 Lincoln Versaille. I have heard that the maybe the cougar used them on soem models. Good luck, John
Old Jan 8, 2004 | 05:36 PM
ferguson777's Avatar
ferguson777
For a 53 - 56 F100 -
" 1989 – 2001 - Ford Explorer – 59 ¼ - ½” flange to flange.
All explorer rear ends are the same 5 on 4 ½” bolt pattern.
8.8” rear end - come with 3.25, 3.55, 3.73 and 4.11 gears.
89-94 = drum brakes only.
94-97 = drum or disc. brakes
97-01 = disc. Brakes only
Can use an 8” rim with 3 ½” backspacing and P235/75R-15 tires"
Should be fairly common in wrecking yards now.
Later,
Old Jan 8, 2004 | 07:45 PM
ozzie 1's Avatar
ozzie 1
Thumbs up
I used a 8.8 diff from a 99 Explorer. It has 3.73 posi, the parking brake cable would be easy to adapte to, and there are lots of these around now. The width is also very close to the stock diff.
There are lots of ratios as Fergson mentioned. Ozzie
Old Feb 11, 2004 | 02:40 PM
svooom's Avatar
svooom
How much should I expect to pay for a disc rear?
I made some calls today and the yards around me want over $450 for an Explorer disc rear. I almost choked. Are these things gold plated or something? Would I be better off looking at some other vehicle? Thanks
Old Feb 11, 2004 | 03:11 PM
Jag Red 54's Avatar
Jag Red 54
A friend just bought a disk 9" out of a thunderbird. (at least I think he said thunderbird) He paid $140. For CA, that sounds about right. I think that the prices are going up as people horde the available inventory then resell at a huge profit. John
Old Feb 11, 2004 | 03:25 PM
truckbuff's Avatar
truckbuff
Brad, you might also check Ford Rangers, the have used both the 8.8" and 7.5" rear ends. Part of the problem you are running into is the Explorer rear end with disc brakes is pretty much still a late model & still on the road so you have to compete with body shops and all the guys upgrading Rangers & Jeeps.
Still the $450 sounds way too high unless it is in excellent shape & ready to use, I've seen new Ford surplus rear ends on ebay for around $600.
Be careful too, on my 99 Explorer the rear end mounts on top of the leaf springs. That's easy to fix, but you don't want to buy a 'good' rear end & then tear it apart.
Old Feb 11, 2004 | 03:34 PM
timucin's Avatar
timucin
i will use mercedes parts.
calipers (used) + disks (new) +mounting plates +pads (new) costs around 250$ + 100$ labor = total will be around 350$
but no handbrake on this aplication..
Old Feb 18, 2004 | 11:40 PM
haroldservice's Avatar
haroldservice
you can use an inline hydraulic brake for a drum to disc upgrade, saves $ on calipers with p-brake.
1972fordhighboy
Feb 5, 2015 05:26 PM
ford1986f250hd
Aug 20, 2011 02:27 PM
BMW2
Oct 19, 2006 04:40 PM
oldhalftons
Aug 18, 2004 02:40 PM
Wildermuth
May 5, 2002 06:30 AM
