Wondering about a disk brake conversion
Old Feb 5, 2015 | 12:36 AM
1972fordhighboy's Avatar
1972fordhighboy
I have a 1972 f250 highboy. It has HD dana 44s up front and dana 60s on rear. I have drum brakes all around. Any suggestions on how to swap the front. Maybe from a late 70s f250. In the rear not to sure because there are no old trucks with rear disk brakes
Old Feb 5, 2015 | 02:12 AM
RichS2659's Avatar
RichS2659
No disc brake kits any more from the one company that was making them for closed knuckle D44's. Only other choice for discs is a later dent 76-79 D44 or a 76-77 D60 low pinion or a 77.5-79 D60 high pinion axle. There are companies that make disc kits for D60 rears. Just google.
Old Feb 5, 2015 | 05:11 AM
tpdaniels's Avatar
tpdaniels
I switched my 72 Highboy to 4 wheel disc braked, on the front I switched the front axle to a 1976 low pinion D44, it is a direct bolt in swap. By using the low pinion even the drive shaft was the correct length. I added a picture from when I was installing it. The rear was not hard to do, I just had to give up my factory park brake, installed a line lock on the rear to compensate for the few times I need park brake. Also added picture
Old Feb 5, 2015 | 05:04 PM
1972fordhighboy
Where could I get the kit for the rear?
Old Feb 5, 2015 | 05:26 PM
HIO Silver's Avatar
HIO Silver
Try TSM Manufacturing.
farmer460
31
Oct 7, 2025 09:25 AM
joelowwatt
29
Oct 28, 2017 11:41 PM
Djstright
Apr 28, 2016 08:44 PM
fordman60
Jan 5, 2010 11:38 AM
