Wheel bearing replacement help
Old Jan 8, 2004 | 09:02 AM
gdavis2265's Avatar
gdavis2265
Hey guys,
my wheel bearings are shot on my Dana 44 HD (large 1ton hub)
What is involved in replacing these?
Old Jan 8, 2004 | 03:10 PM
dfisher1's Avatar
dfisher1
All,
I'm not exactly sure what the one ton rear end looks like?
I know the axles are removable without removing the brakes/drums. They are held in by fasteners at the end of the axle.
Most of these rearends require that you remove the diff. cover and pull the "C-clips". This is fairly easy. Remove the bolt in the spider carrier and then push the axles in a little, the c-clip will be exposed inside the spider carrier and you can remove it. The axle simply slides out at this point and you can take the axle down to the machine shop to have the bearings replaced.
KingFisher
Old Jan 8, 2004 | 03:19 PM
gdavis2265's Avatar
gdavis2265
Sorry,
I should have stated it's the front axle. The 3/4 ton 44 with one ton hubs.
Thanks for your response though.
Old Jan 8, 2004 | 03:24 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Yep, the 44HD has the larger hubs like the Dana 60. Is is disk or drum? If its disk it's just like replacing your rotor. Pull the caliper so you can take off the rotor. Pull the hubs, take off the spindle nut/locks and the rotor should slide right off leaving a spindle buried in a greasy mess If your lucky you don't have to replace your races
Old Jan 8, 2004 | 03:29 PM
gdavis2265's Avatar
gdavis2265
It's a closed knucle with drum brakes, is there a bearing inside the hub that is very hard to get out? Also I went to the local NAPA to get bearings and they did not list any for that axle. What gives, do I have to take them out and have them matched up?
Old Jan 8, 2004 | 03:44 PM
79_250RangerLariat
Ahh, haven't had a closed knuckle of those axles apart for a while. I don't think it was too big of a pain getting them apart, Napa should have the bearings. It all depends on how hard they look.
Old Jan 9, 2004 | 01:44 AM
plowpusher's Avatar
plowpusher
do you know hom to take apart the hubs remove the bolts that hold the lockout pull the lockout off remove the snap ring on the end of the axle if you have the tapperd hubs there is also a snap ring in the hub remove it pull the gear(s) and spring next are the two spanner nutsthe outside one is a lock nut the a spacer lock washerthis has a notch that goes in a slot on the spindlepull it out the one more spanner nut on the drukm brake modles you can remove the drum from the hub by taking out the three screws that hold it on (Ihad to use an impact drive to get mine loose) remove your hub any good manual has a picture you can follow bring the bearings to the parts store by the way the 44hd isjust a 44 with big hubs the one tons all came with 60's up front and that was only the crew cabs in the 70's till 78
Old Jan 12, 2004 | 08:56 AM
gdavis2265's Avatar
gdavis2265
thanks plow- Did my wheel bearings over the weekend. Was very easy. I think I am going to buy a press soon, before I do the other side. I used a brass drift to get the races in and out. I also bout the 4 point spindle socket, so now I'm all set.
Thanks guys
C. Lee Colbert
1983 - 2012 Ranger & B-Series
Jul 3, 2011 12:32 AM
Toyman
Aug 20, 2008 03:41 PM
beatle
Nov 19, 2006 10:47 AM
GB04
Sep 9, 2005 10:41 AM
