Sponsored by: Auxito
engine hesitation
Old Jan 8, 2004 | 12:47 AM
speedaholic's Avatar
speedaholic
engine hesitation
this is a little off topic but could figure out wher to post it, i have a 98 econoline with a v6 not sure as its my sears work van what size but when at a stop when i give it the gas to go it stumbles as if it is going to die the takes off, scary when you are pulling out into traffic and itmoves out but doesnt want to go. sounds like it is backfiring through the intake to sometimes when this happens. any help appriciated. thanks
Old Jan 8, 2004 | 01:26 AM
LxMan1's Avatar
LxMan1
Hi, Welcome to the forum
It should be a 4.2L V6.
How many miles are on it?
Tuned up lately?
I would first try cleaning the MAF.
Does it have a service engine soon( check engine ) light coming on and staying on?
Jimmy
Old Jan 9, 2004 | 12:25 AM
speedaholic
no light
there is no check engine light, as for a tune up i dont think sears does them, just oil and filter changes, van has 125000 miles on it, what would i use to clean maf. thanks
Old Jan 9, 2004 | 12:30 AM
LxMan1's Avatar
LxMan1
Carb cleaner. Just spray the two fine wires in the smaller hole inside the MAF.
If it has never been tuned up, it is due for new plugs and wires.
Jimmy
Old Jan 9, 2004 | 05:06 AM
pyro_thunder_85's Avatar
pyro_thunder_85
Vacuum?
Good place to start, Jimmy.
If that doesn't take care of the issue, check for vacuum leaks using the same carb cleaner.
These motors have a known problem with the rubber vacuum elbow on the underside of the intake manifold collapsing and/or rupturing and causing a severe vacuum loss or leak.
Mine did at 120,000 mi. or so...
Just another thought.....
Old Jan 15, 2004 | 09:33 PM
speedaholic
Talking fixed it
thanks for the info, cleaned the maf sensor and it is now working great.
Old Jan 15, 2004 | 10:06 PM
LxMan1's Avatar
LxMan1
Glad to hear you got it fixed.
wulfman
Dec 22, 2013 04:54 AM
Coalroller
Feb 7, 2012 11:26 PM
toastinloaf
Sep 27, 2011 09:16 PM
nikolass
Mar 1, 2009 03:24 PM
1990Fordf150v8
May 18, 2004 09:08 PM
