Front Axle Question?
Old Jan 7, 2004 | 09:42 PM
Myfine89's Avatar
Myfine89
I have a 1989 F-250 4x4, i was wondering what type of axle was used up front on these trucks? The help would be greatly appreciated
Old Jan 7, 2004 | 09:47 PM
fordmudrunner2020's Avatar
fordmudrunner2020
Welcome to FTE
To answer your question you will probably have a TTB axle (independent and hinges in middle). You either have a Dana 44 or a Dana 50. To tell the 2 apart it is fairly simple. The Dana 50 has clips on the outside of the knuckles and are clearly visaple on top of the caps. The dana 44 has the clips on the inside of the knuckle and are not present on the top of the caps.
Old Jan 7, 2004 | 09:52 PM
Myfine89's Avatar
Myfine89
Thanks for the info, and welcome i like this site alot. would you by chance know the ratio of the dana 44
Old Jan 7, 2004 | 10:01 PM
fordmudrunner2020
It all depends there were quite a few different ratios so you will have to look at the tag on the rear axle on the back on the diff cover held on by a bolt that holds the cover on read the bottom left corner to see the ratio. example mine is 4L10 that means it has 4:10 gears with limited slip. Don't get alarmed if your tag isn't there sometimes they get torn off.
Old Jan 7, 2004 | 11:06 PM
MustangGT221's Avatar
MustangGT221
I think there is also a sticker on the back of one of the suspension arms.
Old Jan 8, 2004 | 04:36 AM
andym's Avatar
andym
Only on newer trucks. You can also decode the number under 'axle' on the door post sticker. Do a search.
Powermonger
Sep 29, 2011 06:35 AM
FORDMAN F2011
May 3, 2011 05:15 PM
4xfordman
Feb 9, 2002 11:24 PM
