1978 - 1996 Big Bronco
rear end ?
Old Jan 7, 2004 | 01:13 PM
lookingtosoar's Avatar
lookingtosoar
rear end ?
First of all thanks to all on this site. the information here is awesome. i have learned so much here.
i have a 78 bronco and was wondering what year rearends will work in my truck. i have one out of a mid 80's that i want to put in will it works. thanks in advance for all the information.
Old Jan 7, 2004 | 01:35 PM
96XL's Avatar
96XL
your truck should have had a 9" i believe and the mid 80's rear depending on what it is out of could be a 8.8 or a 9" or many others. you need to find out what you have before you begin the swap.
Old Jan 7, 2004 | 03:40 PM
lookingtosoar
i have a 9" rear end and the one that i am replacing it with is a 8.8 out of a 88 bronco. i am wanting to change out the whole axle. will this bolt in or should i go with something else
Old Jan 7, 2004 | 07:08 PM
BB94Bronco's Avatar
BB94Bronco
It will deffinatly bolt in but why would you want to downgrade to an 8.8 ???
The only issue you may have is finding the right U joint to match up your shaft with the 8.8 .
Old Jan 7, 2004 | 10:40 PM
lookingtosoar
well mine is shot and the 8.8 is being given to me so thought i would use it to get if back on the road and not just sitting in my garage
Old Jan 7, 2004 | 10:48 PM
BB94Bronco's Avatar
BB94Bronco
Well if the ratio is the same it's ok for a temp , but I think you should get the 9" rebuilt . It wouldn't be as expensive as you think to get it rebuilt .
LinwoodP350
Large Truck
Jul 8, 2021 12:16 PM
oldmx
Oct 3, 2016 06:56 PM
Bcm31643
2015 - 2020 F150
Jun 20, 2015 06:39 AM
jcarrAZS
6.7L Power Stroke Diesel
Mar 30, 2012 09:01 PM
Pokendeye
New Member Introductions
Sep 25, 2007 04:01 PM
