Sponsored by: Real Truck
Turn Signals
Old Sep 16, 2002 | 02:20 PM
Yeti's Avatar
Yeti
Turn Signals
Old Sep 18, 2002 | 10:54 AM
BOBBIE43's Avatar
BOBBIE43
Turn Signals
:P Im was driving home and generally avid user of my turn signals , so all of a sudden signal just stops blinking, the indicator is lite and i could see the yellow refection on the turn signal on the car infront of me This happened on R/L sides intermitently, this A.M. they worked fine , its a 02, 250 S.D. CC, v-10.....Thank you
Old Sep 18, 2002 | 07:31 PM
HarryO's Avatar
HarryO
Turn Signals
Generally speaking, if the indicator is on steady (no blinking), then your flasher (typically a small can shaped device, under the dash or in the fuse box area) has stoped working.
I don't think that one of the light bulbs (front or rear) might be burned out because you would have noticed the rate of flash changing (faster blink rate).
Do your emergency flasher still work? If not, is is the flasher.
I know, I know, I just can't think of the correct name of the flasher.
HarryO
Old Sep 18, 2002 | 10:11 PM
Monsta's Avatar
Monsta
Sit. Stay.
Turn Signals
Turn signal relay??
__________
When the turn signals work, follow the clicking... Pull it out and replace it. They are cheap. Meaning: little $.
Old Sep 18, 2002 | 11:08 PM
S_DutyFord's Avatar
S_DutyFord
Turn Signals
Some time ago, (maybe you remember my first post) the same thing happened to me. It turned out that I had water in my trailer wiring hook up. The flap that is supposed to keep water out was actually holding water in. I cured the problem by drilling a hole in the bottom of the hook up. You maye want to check this if you have a trailer harness, because I didn't figure out what the problem was right away and eventually it blew out my fuses.
Keith
Old Sep 19, 2002 | 04:08 AM
BOBBIE43's Avatar
BOBBIE43
Turn Signals
, Thanks all for the help, now going to get Tires rotated
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
