Sponsored by: Real Truck
Tuff Country leveling kit
Old Sep 16, 2002 | 11:57 AM
BikNut's Avatar
BikNut
I installed a 2.5inch leveling kit on my F-250 it came with a new track bar bracket. Ever since I get a popping in the front a it squeks in the front springs like crazy this really gets on my nerves but it looks so good. Anyone know what the problem could be? Thanks in advance.
Old Sep 16, 2002 | 02:20 PM
Yeti's Avatar
Yeti
Make sure the bolts holding the track bar bracket to the frame are tight, the popping noise could be the bracket seperating and then popping back and hitting the frame.
I replaced the stock hardware with a beefier grade bolts on my truck.
Have someone turn the wheel from left to right and keep your eye on the bracket,where it meets the frame. Of course make sure the vehicle has the emerg brake applied
Old Sep 16, 2002 | 08:06 PM
PSD_Power's Avatar
PSD_Power
>what the prob#####uld be? Thanks in advance.
I Had the exact thing hapen on my same lift. you need to air ratchet the bolt on the top of the track bar as tight as it will go with the air ratchet. that is the only thing that fixed it for me. What year truck is it.?
Justin
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=8262&.jpg
http://66.179.41.42/gen1/build/realgeneral.jpg
2002 F-350 SC LB 4X4 6SPD PSD. 3.73 gears. 2.5" leviling kit. K&N air filter. Rhino lined Bed. Prodigy trailer brake controler. 35x12.5x16.5 BFG A/T. 16.5x10 ultra wheels. pop up gooseneck hitch and firestone airbag spring helpers. Delta toolbox
Old Sep 17, 2002 | 12:14 PM
BikNut's Avatar
BikNut
Its a 2001 F250 regular cab long bed I am running 35x12.50S on 16.5x12 Mickey Thompson wheels I get alot of compliments on the truck but I hate the pops and squeeks. Hope your remedy works for me too.
Old Sep 17, 2002 | 02:01 PM
CBSuperduty's Avatar
CBSuperduty
BikNut...Any chance for some pics I would like to see how your wheel/tire combo looks with that suspension. Did you have to do anything to keep it from rubbing????
Old Sep 19, 2002 | 09:18 AM
BikNut's Avatar
BikNut
CB I will try and post some pictures in a few days, never done it before.
Old Sep 19, 2002 | 09:36 AM
CBSuperduty
