$80 For Replacement Key....HELP!!!!
The Expy itself shouldn't be higher just because it's an Expy. Does your Ranger have the PATS keys?
Yes, it is the PATS key. Extra PATS keys are $19.95 if you have 2 keys. This inclludes key, cutting, and programing.
On-Board Programming Method "C"
for Ford keys (Later 1998-newer Ford, Lincoln, Mercury)
If you want to initiate a new master key....
1. This requires that the vehicle be connected to special dealer equipment. There are two ten minute delays involved while this device erases all existing key programming and sets up the vehicle computer to accept new key codes. Two new keys should be ready because the system requires a minimum of two keys in the program. After the first two keys are programmed, additional keys can be entered individually by following the instructions for adding duplicate keys (below).
If you want to add a key....
**You must have two original keys to perform this procedure. If you only have one key, you WILL have to take it to the dealer to get it programmed**
1. Insert and existing (working) key into the ignition cylinder.
2. Turn the ignition cylinder ON (RUN) and back to OFF. Ignition should stay on for at least ONE SECOND.
3. Remove the existing key and, within TEN seconds, insert a second working key and turn it to ON (RUN) and the back OFF. Ignition must be in ON for at least ONE second, but no more than TEN seconds. Remove the key.
4. Insert the new key before TWENTY seconds have elapsed and turn it to ON (RUN). Leave it the ON position for at least ONE second and turn back to OFF.
5. The security light will light up for THREE seconds to indicate that the new key has been successfully programmed.
6. To program additional keys, repeat steps 1 through 5
As a precautionary measure for all of the above procedures, you should wait at least one minute after you have performed this until you start your vehicle.
I received my extra keys and remotes in the mail today. Went to Wal-Mart to have keys cut however Wal-Mart said they could not do it since they use a cartridge base cutter. So I decided to take my spare keys to the dealership to be cut. Service wanted to charge me 15.00 dollars to cut one key! Also, they really don't cut keys unless it comes from the dealership. That's the last time I go to TEAM Ford in Alpharetta again. To make a long story short I went to ACE Hardware to have my keys cut. So for $5.00 I got both of my new keys cut. 5 minutes later both keys were programmed.
Thanks again for the EBAY information. I paid a total of $45 for 2 sets of keys and 2 keyless remotes. The $45 includes the cutting and shipping charges. If I had purchased one key and one remote from Ford I was looking at about 100.00 dollars (key = $50 remote also about $50) and that doesn't include the extra $40 they charge to program.
