power steering conversion 90% need info
Old Jan 5, 2004 | 12:44 AM
1973fordproject's Avatar
1973fordproject
Question power steering conversion 90% need info
has anybody heard of an aftermarket adapter plate to adapt a 1978-79 power steering gear box to a 1973 frame? 1973 f-100 4x4
Old Jan 10, 2004 | 10:01 AM
lowcountry's Avatar
lowcountry
What kind of steering do you have now manual or power assist?
I adapted my 74 to power steering with no adapter plate
Old Jan 10, 2004 | 10:06 AM
jj292's Avatar
jj292
all the steering boxes manual or power from 73-79 will interchange as a direct bolt on. Just remember to get a 4x4 one if you have a 4x4 or a F250 one... etc.
JJ
Old Jan 10, 2004 | 10:12 AM
lowcountry's Avatar
lowcountry
When i changed from a manual to power steering i had to re drill the frame because the manual box i had the pitman arm going to the rear and the power box went out the front, had to move the box back I believe 3 or 4 inches
Old Jan 10, 2004 | 10:18 AM
1973fordproject
I HAVE A 1973 F-100 4X4 AND HAVE CHANGED THE FRONT END TO GAIN DISC BRAKES, I ALSO CHANGE THE STEERING GEAR BOX.THE NEW BOX ONLY HAS THREE BOLT HOLES THE FRAME HAD FOUR.
I PROCEEDED ANY WAY ONLY USING THE THREE, SINCE EVERY THING HAS WORKED WELL UNTIL RECENTLY. THE BOX WORKED LOOSE AND WHILE TIGHTENG IT BACK ONE BOLT PULLED RIGHT THROUGH THE FRAME. LOOKING FOR A MORE ADAPTABLE APROACH THAN FABRICATING.
Old Jan 10, 2004 | 11:18 AM
Nod's Avatar
Nod
Power Steering Conversion
1973Fordproject,If your truck is a 4x4 I can send you my article on how to add power steering to that truck.I am starting a PS conversion on a 1976 F-100 4x4 next week as I have finally got all the parts together.If you send me your e-mail address I will send you a download of my article.I did this conversion on my 71 F-100 4x4 about three years ago and it is still running strong.Have fun.
"bowties in the rearview mirror"
Old Jan 12, 2004 | 09:21 PM
1973fordproject
Nod i cant e-mail you i havent been a user long enough. try this & see if it works.... tjamisonm @ msn.com
DREW148BHP
1966 - 1977 Early Broncos
May 17, 2010 11:26 PM
1965GTFB
Mar 23, 2010 03:32 AM
pcta12
Sep 11, 2006 12:57 PM
Bob Crain
May 19, 2005 04:59 PM
kingobar
Feb 18, 2003 05:42 PM
