Sponsored by: Auxito
Speed Control not working
Old Jan 4, 2004 | 08:28 PM
pops_91710's Avatar
pops_91710
I just purchased a gorgeously red 2000 F-150 XLT Lariat for my son. We have discovered the cruise control is not working. Is there any way to diagnose this problem with out a scanner? I have read elsewhere there is a self-diagnosis, but it was on a '95 Aerostar.
Fuses check good, all that stuff. Any suggestions?
2000 XLT Lariat F-150 Supercab, 139" wb, 5.4, auto, 2WD.
Old Jan 4, 2004 | 09:07 PM
pops_91710's Avatar
pops_91710
okay...scratch that request. The one I read on this site for the guy with the Aerostar worked!!! By the way, this truck hauls ***!
My F-250 doesn't come near it even with the Diablo chip. Is the weight difference that much?
Old Jan 4, 2004 | 10:04 PM
Racerguy's Avatar
Racerguy
So did you figure out the problem?
Old Jan 4, 2004 | 10:50 PM
pops_91710's Avatar
pops_91710
Well, it's working, so I guess the trick I used actually resets it. I held the off button down, turned on the key and waited for the cruise control light to flash, then pushed all the rest of the buttons in their described order, heard a few thunks in the dash or firewall area (strange) and took it out for a spin. (I found the instructions on this website.)
My son and I bought it Friday night. He test drove it, then drove it home, so I never did try it until tonight to see if I had done any good to the cruise control.
I couldn't believe how quick that thing pulls from a dead stop! It out accelerates my new F-250 by quite a ways! It's way fun!! My 250 pulls strong, but maybe it's smoother so it doesn't seem to pull like his does.
Old May 2, 2004 | 07:29 PM
edivaldo's Avatar
edivaldo
Question Reset for Speed Control
Hi,
I saw your message regarding the reset on the Speed Control.
Could you please send me the complete sequence to reset it?
I have a Ranger 97, and the speed control was having no signal of life. Then I tried the "press off button and turn-on the key" and the lamp blinked on the instruments panel. So, I believe I have some chance to see it back, heh, heh...
Thanks in advance.
Edivaldo
Sao Paulo - Brazil
Old May 2, 2004 | 08:16 PM
pops_91710's Avatar
pops_91710
1. Fully engage parking brake. Make sure brake peddle is released.
2. Begin static portion of self test by pressing and holding speed control off switch.
3. Turn ignition switch from off to run. The cruise indicator on the instrument cluster will flash once to indicate the speed control module has entered diagnostic mode. If the cruise indicator does not flash repeat steps 1-3. If the cruise indicator still does not flash, diagnose the cruise indicator.
4. Release the OFF switch
5. The cruise indicator will flash when each switch is pressed. While performing self test. Press each switch in the order described while observing cruise indicator for a flash. Note any switch activations that does not cause a flash. Within five seconds of turning the ignition switch to RUN:
Press the ON switch.
Press the RESUME switch.
Press the COAST switch.
Press the SET/ACCEL switch.
6. NOTE: the ON switch must be pressed within five seconds after entering the diagnostics mode or the speed control module will return to normal operating state and self-test must be repeated.
Flash Code Function Tested Possible Cause
0- Speed Control Servo Speed Control Servo Defective
1- Complete System
2- Stop Light Switch Circuitry Stop Light Switch Circuitry
3- Brake Deactivation Circuitry Brake pressure control valve defective circuitry
4- Vehicle speed sensor- Vehicle Speed Sensor Out of range
5- Speed Control Servo Speed Control- servo defective
Old May 2, 2004 | 08:30 PM
edivaldo's Avatar
edivaldo
Smile Thank You so much!
Hi pops, I just executed the procedure and got 3 blinks, so, I will check the "Brake Deactivation Circuitry Brake pressure control valve defective circuitry".
Regards,
Old May 14, 2004 | 08:32 PM
TexAcoon's Avatar
TexAcoon
If you checked the circuit and all is indicating readings from the steering wheel to the plug in to the module (diaphram control).
Could the module in the diaphram control be bad?
Or
Is there something else I should look for?
Thanks!
Old Jun 10, 2004 | 10:58 AM
myke's Avatar
myke
does anyone know if this works for all fords? the cruise in my wife's '94 t-bird hasn't worked in quite a while.
troverman
Feb 14, 2026 05:30 PM
Greenie326
2015 - 2020 F150
21
May 5, 2015 04:34 PM
FordOwnerJoey
Mar 25, 2015 03:14 PM
90turbo1
Dec 30, 2013 11:47 PM
pwelch2002
Nov 15, 2011 02:42 PM
