tire question
Old Jan 4, 2004 | 10:22 AM
mrw1125's Avatar
mrw1125
tire question
Does anyone know what is the largest tire that can be put on a stock susp. and rims without rubbing. I will be adding a spacer in the front to help a little but i just want the biggest tire i can get without going to a lift.
Old Jan 4, 2004 | 11:00 AM
aurora_1's Avatar
aurora_1
295s will work just fine. The 305s would also clear, but not sure if they are appropriate for stock width rims. I know some guys have put 315s on stock, but that is way to big for the 7" rim. But 315 do rub in tight turns with any suspension compression also. Now in the above statement, I'm assuming you have heavy service or better front springs (V rated). Lower rated springs may cause the 305s to rub in certain situations.
Ford dealers can handle speedo recalibration for 285s (costs about $60 or so), anything bigger takes more effort on their part as the programming must be fooled a little to correct for larger tires. Some dealers will not do anything larger than 285 tires.
Old Jan 4, 2004 | 12:01 PM
pappaduck's Avatar
pappaduck
I run 305's with no problems.
Old Jan 4, 2004 | 02:31 PM
mrw1125's Avatar
mrw1125
thanx guys for the info im glad to hear that the 305's work bk that is what i was aiming for
BELLBEAR
2004 - 2008 F150
Mar 6, 2011 09:54 AM
wilbilly216
20
Mar 11, 2010 08:40 AM
maxfordfan
Jul 17, 2003 06:41 PM
koolbreeze
Jun 24, 2003 09:42 AM
vdub8
1978 - 1996 Big Bronco
Sep 25, 2000 03:56 PM
