Got 'er put back together yet?
I'm working on mine in the driveway as weather permits. Decided to go after the timing chain while I was at it, got that in today. Heads next, after some scraping and cleaning on the block. They couldn't fix my crack, either, so they rebuilt another one for me.
I do believe that next time I do all this, I'll just pull the engine and work on it in the garage on a stand.
So how did reassembly go? I haven't posted here in a while...about 10,000 projects came up around the house, and the ol' truck was put on hold. I am getting the head machined next weekend, so the fun assembly project starts for me soon...
c96drumm- I am/was working on kind of the same thing as you guys. Lost compression (all of it!) on cyl 6. Discovered a slightly bent valve.
Got it all back together no problems. 2 Rebuilt heads, new lifters, new gaskets, NO LEAKS!
I think the valve had been broken for a very long time. When I assembled everything again I heard the same ticking noise I heard in the first place and found out it was crappy header gaskets. New gaskets and it sounds and runs great. And I have more power now.
Finally finished mine. Runs fine, so far. (knock on wood) Don't really think I have any more power than before the valve burned and the head cracked. I hoped it would be a little zippier because I had the injectors cleaned and I cleaned all the carbon and stuff from the intakes and pistons. Replaced the timing chain, too.
How's yours coming along there, bdonalds?
Originally posted by c96drumm How's yours coming along there, bdonalds?
Well, slow...!!!
I finally got into a shop to to the valves and seats last weekend. One head is done, but unfortunately, we found a small crack in the other one. Ir runs through the seat.. I'll put a picture of it in my gallery when I remember...
So, I have to head to the junkyard to get a head, and both exhaust manifolds. How much did you pay for your head? Yours was a refurb, right?
