removing a 390 starter
Old Jan 3, 2004 | 09:22 PM
ford390gashog's Avatar
ford390gashog
how do you go about removing a starter off a 390
Old Jan 3, 2004 | 09:41 PM
ranger429's Avatar
ranger429
take the two bolt's out that retain it to the transmission and undo the battery cable, make sure to disconnect the POS cable at the battery first
Old Jan 3, 2004 | 10:04 PM
ford390gashog
thanks
EDIT: anything special when installing one
Old Jan 3, 2004 | 11:50 PM
samckernan's Avatar
samckernan
Hey, I don't know if this is valid, but on my 72, 3/4, 360, AT:
If you look at the starter from the front of the truck, there are bolts that go through the starter into the bellhousing (is it called a bellhousing on an AT). One at 6 o'clock, another at 10 o'clock, and a third one at 1 o'clock.
The ones at 6 and 10 were easy, but the one at 1 o'clock was a real pain in the rear. I had to get 2, six inch, and one, 4 inch socket extender and snake the socket to the bolt along the side of the block, up under the exhaust manifold. Like I said, it was a pain in the rear.
If this isn't valid for your application, please disregard.
Sam
Old Jan 4, 2004 | 02:22 AM
luvfordtrucks's Avatar
luvfordtrucks
yep, what they all said, unless it' has headers on it.....
Old Jan 4, 2004 | 07:27 PM
astute observer's Avatar
astute observer
Yep, three bolts on an FE.....two on a small block. But the starter itself is otherwise basically the same. I've switched end plates in order to use one on the other with no problems.
Old Jan 4, 2004 | 08:00 PM
ol yeller's Avatar
ol yeller
On my 352 I used the extension method also. Changed the top bolt to a stud so I could start the nut a little easier.
Dave
Old Jan 4, 2004 | 09:18 PM
rebocardo's Avatar
rebocardo
The easiest way to get the top one is to cut the strap on the fender (if it has not rotted away already) and pull the inner fender out a bit and reach right in for the bolt. Also, handy for changing the exhaust.
Old Jan 5, 2004 | 11:55 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I have a 30-year-old Snap-On 1/2" u-joint socket that works perfect on that top bolt.
Per another discussion about FE starters, compare the starter gears to make sure you get one with the same number of teeth.
Some parts places just think "three bolt" or "two bolt" ford starter. Turns out that I have gotten at least one coarse-toothed starter when I didn't want one. I don't think it was so much the parts store, but the rebuilder not giving a damn about the number of teeth, just the number of bolts.
Old Jan 5, 2004 | 04:46 PM
oldroady's Avatar
oldroady
24" straight 3/8" extension for the top bolt. wrench is all the way at the front of the engine, where you can get a hold of it. do remember to take the pos cable of the battery first.
Old Jan 5, 2004 | 04:50 PM
51F3's Avatar
51F3
The infamous top bolt! I just hope you are doing it inside a warm garage. In ten degree weather it is a b****!
Old Jan 5, 2004 | 05:05 PM
rusty70f100's Avatar
rusty70f100
Heh, the fun top bolt. The way I do it is to tie some dental floss around it, so that when you drop it down into the bellhousing (or behind the starter) you can get it back and try again. When you get it in, cut the dental floss off as close as you can to the bolt.
Old Jan 5, 2004 | 05:18 PM
51F3's Avatar
51F3
I had to remove the bolt on a 1963 Galaxie XL. Never did do it on a pickup. But then again.....a 390 is a 390 is a 390!
Old Jan 8, 2004 | 05:38 PM
yomow's Avatar
yomow
Never remove the posi cable first Remove the neg. only If you remove the posi cable first & the tool hit a ground it will spark. How can the neg. cable spark unless you hit a posi. cable . If you remove the ground an't nothing going to happen. Don
greentruck72
19
Dec 6, 2016 11:40 AM
csharris
Apr 10, 2016 05:01 AM
Ford59galaxie
Mar 28, 2012 08:08 PM
BigNug45
Aug 23, 2010 02:57 PM
mike390
Electrical Systems/Wiring
Aug 2, 2004 09:09 PM
